Old 12-16-2014, 06:18 PM   #1
muley
muley's Avatar
Manual 4 speed headers
Greetings all;
I have 1969 chevy pickup, 350 and sm 465 trans with manual clutch linkage. Is there a good fit header for this application so the clutch linkage works, or should I stay with the stock manifolds?
Grandpa 1953 M38A1 Jeep
1989 GMC K2500
1958 Alaskan Camper all original
WORK : A necessary evil that finances
what I really like to do.
muley is offline   Reply With Quote
Old 12-16-2014, 06:41 PM   #2
meangreen72gmc
Re: Manual 4 speed headers
I had to put a bend in the z bracket and also a slight bow in the push rod to get my headers to clear. Its a trial and error process. Doesn't take too much bend in the push rod. Too much and it will be rubbing the oil filter. I used summit brand long tubes.
1972 GMC K25 350 sm465
1969 GMC C15 350 th400
2009 Chevy Silverado 1500
meangreen72gmc is offline   Reply With Quote
Old 12-16-2014, 07:16 PM   #3
BLT gmc
I used JBA 1815 on my 69 GMC K10. They fit excellent. I am not much help for the 2WD. Bruce
BLT gmc is offline   Reply With Quote
Old 12-16-2014, 10:37 PM   #4
landy
I vote for keeping the stock manifolds. Seems like the headers I've had always leaked somewhere. I suspect the performance gains would be marginal with headers over stock manifolds unless you've got a "hot" engine.
landy is offline   Reply With Quote
Old 12-16-2014, 10:43 PM   #5
rwolf9653
more ideas than money
rwolf9653's Avatar
Interesting. I was able to put on summit long tubes with no modifications at all, but I am what feels like the 8000th owner of the truck.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 12-16-2014, 10:58 PM   #6
meangreen72gmc
2wd or 4? Mines 4 and I didn't have to put much bend at all. Just a little tweak
Old 12-16-2014, 11:07 PM   #7
Lattimer
Lattimer's Avatar
I did the summit long tubes http://www.summitracing.com/parts/sum-g9006-9
Fit good except I had to modify the z-bar. My small block is in the L-6 position, and the Z-bar is still in the L-6 mount and the swivel ball is threaded directly into the block. I think if everything was in the V-8 I'd have more room and the z-bar would clear.
I had to move the bottom arm over about 2" and bend the rod going down to the clutch arm. Not bad for a bastardized truck.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 12-16-2014, 11:14 PM   #8
meangreen72gmc
Sounds like we used the same exact headers and had to do the same exact modifications. Not a problem at all as long as you have a vice, hammer, and heat(optional).
Old 12-17-2014, 12:11 AM   #9
Lattimer
Lattimer's Avatar
I actually cut the arm off, moved it over and welded it back on.
Shawn
Old 12-17-2014, 08:15 AM   #10
meangreen72gmc
I remember thinking about doing that but decided just to bend it at the base and straighten it back out at the tip because I didn't need it to move quite as much. But to the OP its not that hard either way. This is the route I would take if I had to do it all over again.
Old 12-18-2014, 12:31 PM   #11
muley
muley's Avatar
Wow. Got super busy, but finally got back to this. Thanks to all for the help here. I was thinking back in the 1970's how everyone had car and motor parts laying around and you could just use your friends Impala or Camaro headers and see if you can make them fit. If you find something you like, he usually wanted an AFB carb or something and you were both happy. It was surprising how many different cars you could adapt a 327 into and make Impala headers work. Fun times!
1989 GMC K2500
Old 12-18-2014, 01:42 PM   #12
Swar
Swar's Avatar
If you're not set on long-tube headers, check out Tru-Ram headers from Speedway Motors. They won't interfere with the clutch linkage, and you can them in stainless steel if you want them to outlast the rest of the truck.
Swar is offline   Reply With Quote
