Old 12-16-2014, 08:59 PM   #1
1972BlueC20
1972BlueC20's Avatar
passenger turn signal not flashing
Sorry if this is a simple fix and dumb to ask, but all of the sudden my passenger side turn signal doesn't click or flash. It just stays solid green when you try to turn it on. The driver turn signal works fine.
Also the passenger turn signal stays constantly glowing dimly green.
What could be wrong?
It just started randomly tonight after messing with my trans Kickdown cable. I don't think I bumped anything, if there is even anything to bump in that area that would cause any issues with the passenger turn signal.
Thx in advance!
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 12-16-2014, 09:00 PM   #2
cdowns
cdowns's Avatar
Re: passenger turn signal not flashing
bad light bulb
Old 12-16-2014, 09:20 PM   #3
rocknss
rocknss's Avatar
X2
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 12-16-2014, 09:43 PM   #4
1972BlueC20
Wow I wish all problems were that easy to fix. This is the first time I've had a bulb go out since owning this truck so I didn't know what if anything happens when a turn signal bulb goes out.
It was the front parking light. Swapped in a new # 1157. Works perfect now!!
Thx guys!
