Rear wheel tubs
Hey guys I'm looking for info/pics on how the rear wheel wells come out. Notched my frame in my 63 burb and need a little more room for the tires. I don't want to start cutting if they will unbolt and come out easy. Thanks.
Street Steel 1978 C-10 Build Thread http://www.67-72chevytrucks.com/vboa...17#post5327317 |
Never Ending Projects
Re: Rear wheel tubs
You should have bolts up in the wheel well that hold it to the side and bolts you can get from underneath that mount the flange part to the floor. The are completely bolted in.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: Rear wheel tubs
Sweet. I see the bolts on the inside. There is a lot of crud on the under side. I'm sure if I clean it off I'll see the other bolts lol. Thank!
