12-16-2014, 11:22 PM | #1 |
69 gmc 4x4 front leaf spring install help
I have a 69 GMC 4x4 1/2 ton that I am replacing the front leaf spring bushings on. Got the bushings all installed but I am finding the front bushing steel insert is a little wider than the hanger. So much it won't go in and I don't want to tear up the insert. What's the best method for getting it in there? Heat the hanger and widen? Any suggestions are appreciated.
Kirk 69' GMC 1/2ton 4WD 355ci 4speed |
12-16-2014, 11:41 PM | #2 |
Re: 69 gmc 4x4 front leaf spring install help
Just figured out it is the wrong part....back to the parts store. About a 1/4 inch too wide. Yep, I'm new at this.
12-17-2014, 12:39 AM | #3 |
20' Daredevil (Ret)
Hope the new part fits better. I had the same issue when I put the Softrides on my K20, but far less than 1/4". One of the metal inserts was too long so I ground off just enough that it would fit, probably around 1/16" or so IIRC. The other side either just fit, or maybe took just a bit of grinding.
12-17-2014, 10:45 AM | #4 |
I am glad you found the right part. I had the same truck same problem. I did have the right part, but the PO's had over-tightened the bolts and artificially narrowed the mounts. Nothing but hard work to widen them back out. Bruce
12-17-2014, 09:33 PM | #5 |
I had same problem with the krapjacker soft rides. Grinder did the trick.
White K20 |
