Old 12-17-2014, 02:32 PM   #1
Fummins04
55 Chevy LS build thread
Hello to all the members here! New to the forums and the build..Figured I'd join the party and post my build as it goes. Won't be the fastest build but should be lots of fun and learning along the way!
Been in search of a older Chevy truck for a while now finally found a good deal locally..Picked up the truck just this past weekend Dec. 15,2014.. Basically I'm starting with a solid shell.. Cab,bed,hood,rear window and side windows are all there.. Frame is factory.. However someone already installed some kind of mustang II front end which is a plus! As well as supplying me with a ford 9in and C- notching the rear as well and welding tabs for the 4 link. However I plan to cut the rear out and redo it all my way because I'm not satisfied with previous owners welds and design.
So plan of attack is to start at the back and work to the front to make a solid rolling chassis then go to front along with brakes n steering! Any insight please share ideas info before or along the road of this build! And bare with my while I try to figure out how to upload pics from my phone
Fummins04 is offline   Reply With Quote
Old 12-17-2014, 02:37 PM   #2
Fummins04
Re: 55 Chevy LS build thread
Hopefully the attached picture will post/load
Old 12-17-2014, 02:38 PM   #3
Fummins04
Here's a picture of the frame before I loaded it onto the trailer
Old 12-17-2014, 02:40 PM   #4
Fummins04
As we loaded the cab onto the trailer to bring her home!
Old 12-17-2014, 02:43 PM   #5
Fummins04
And one more pic before we get started on the build! Progress pics will be added as well with info
Old 12-17-2014, 02:59 PM   #6
58CameoAZ
Good Luck with the Build!
Looks you are off to a Good Start.
Allen
58CameoAZ is offline   Reply With Quote
Old 12-17-2014, 04:25 PM   #7
Kim57
Kim57's Avatar
Welcome.
Looks like a nice solid truck to start with.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-18-2014, 12:26 PM   #8
Az. Hank
Az. Hank's Avatar
I like the ride height sitting on the trailer.
Az. Hank is offline   Reply With Quote
Old 12-19-2014, 05:54 PM   #9
Fummins04
So looks like I had a few things come in for the truck so far. Rear Air bags here
Old 12-19-2014, 05:57 PM   #10
Fummins04
Also picked up my motor for this build. 05 5.3 102k miles from Georgia. Needs a bath!
Old 12-19-2014, 05:59 PM   #11
Fummins04
4 link bars n brackets
Old 12-20-2014, 02:09 AM   #12
Kim57
Kim57's Avatar
Nice stuff.
Kim
My build thread
Old 12-20-2014, 02:24 AM   #13
Daze57
Daze57's Avatar
good lookin build!
Daze57 is offline   Reply With Quote
Old 12-29-2014, 10:56 AM   #14
Fummins04
Managed to Work on the truck all weekend. Had my buddy stop by n lay down some nice beads for me n made some nice progress!
Old 12-29-2014, 10:58 AM   #15
Fummins04
Here's the old if you wanna call it, C-notch we cut out.
Old 12-29-2014, 11:07 AM   #16
Fummins04
Here's how the truck sits as of Sunday night. 4 link, bags, and brackets installed. Few small things left in the rear to do like shock tabs n cut the bed clean to clear a new set of rims an tires and such. Back to work for the week, hopefully get back on the truck over the new year.
Old 12-29-2014, 12:15 PM   #17
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
Old 01-10-2015, 10:35 PM   #18
Fummins04
Been a few weeks but figured Id update here. Got the motor mounts welded in and dropped the cab down on the motor n tranny to make sure everything fits. Will need to tunnel inside the cab for the transmission and make a trans mount still.
Old 01-10-2015, 10:36 PM   #19
Fummins04
Here's a picture with the ground clearance
Old 01-10-2015, 10:43 PM   #20
Fummins04
Ordered new upper an lower control arms from speedway rather then dealing with pressing new bushings in my existing control arms. Also ordered my disk brake kit to switch it to 5 lug to match the rear 5x4.5 pattern. Next step is to install all that front end stuff along with the bags. Currently waiting on all my air fittings to do that too! Slowly but surely coming along!
Old 01-10-2015, 11:29 PM   #21
Advanced Design
Advanced Design's Avatar
Looks good, especially with the truck pan higher than the cross member.
Advanced Design is offline   Reply With Quote
Old 01-11-2015, 12:18 AM   #22
Kim57
Kim57's Avatar
That's going to be low.
Kim
My build thread
Old 08-11-2015, 05:56 PM   #23
Fummins04
Well I know it's been awhile but been super busy. Finally had a lil time I figured I'd get back on here and update the build! Ended up scoring a 58 big window fleetside Apache. Ended up putting the 55 Chevy on hold since the 58 was further along as far as being a complete truck and more of what I wanted anyway!
Here she is waiting to be loaded up to come home!
Old 08-11-2015, 05:59 PM   #24
Fummins04
Finished up the frame and here it is back from Powdercoat and assembly started
Old 08-11-2015, 06:08 PM   #25
Fummins04
Got the fuel cell,air tank,and rear components in.
