Old 12-17-2014, 03:28 PM   #1
w00dst0ck
w00dst0ck's Avatar
What pieces not to use on 88-98 brake setup
Running CPP Disc brake setup on my '65 with CaptainFab booster bracket.
Pulled a complete booster/MC/isolation valve/proportioning valve off a mid 90's 1500 with RWAL (didn't get the RWAL obviously).
Will the isolation valve work in the system or should I just get rid of it and go straight from the proportioning valve and cap the top outlet to the dump valve?
w00dst0ck is offline   Reply With Quote
Old 12-17-2014, 03:45 PM   #2
w00dst0ck
w00dst0ck's Avatar
Re: What pieces not to use on 88-98 brake setup
Nevermind. Apparently deleting the isolation valve is very common on the 1500 forums, as it's prone to failure.
