Keyway Pulley Puller Tool
Hi all!
Thank you in advance. I'm stuck. My power steering pump went bad. I am looking to buy the right tool for a keyway power steering pump pulley for my 1971 Chevy C20 350. I previously used a generic pulley puller but I could not get my pulley back on with the generic tool. The manual calls for special tools. I do not have the manual in front of me, but I can post a pic of the tool specs later when I get home. I've attached a pic of the pulley. |
Re: Keyway Pulley Puller Tool
any local autoparts store should have the proper tool it is about $12
Moderator
![]() Join Date: May 2007
Harbor freight carries it too. You need this instead of a three jaw puller
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Moderator
Stuff inside
Not to bogart your question but i think i am having power stearing problems. When ever im stationary and try to turn the wheele its turns very rough. Any thoughts.
![]() Join Date: Jun 2005
The style that uses the nut is not a press fit but if it's been on there a while you may need a puller to remove it. After you get it off put some never seize on the shaft and you should be able to remove it by hand after that.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Tags |
#keyway, #powersteering pulley, #pulley, #pulley puller |
