Old 12-17-2014, 06:12 PM   #1
Mjminino
Firewall Holes
Obviously I see which one is for the steering and i know which one is for the heater, but what are all the other holes used for?
Mjminino is offline   Reply With Quote
Old 12-17-2014, 07:04 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Firewall Holes
ok: red: heater bolts, and lower right as you look at it, heater fan wire grommet.
green: engine harness
orange: choke& accessories
maroon: rear wiring harness
lavender: throttle assembly
violet: clutch rod
light blue: brake and clutch pedal assembly bolt holes
white: main wiring harness
that should cover most: some of the smaller holes are bolt holes, and firewall pad holes, also there are attachment holes to route the wiring...
** I missed 2, is yours a 66? the hole next to the clutch rod hole is for the reverse light wire, and the square hole under the steering column is for the emergency brake cable.
Old 12-17-2014, 07:09 PM   #3
Mjminino
Re: Firewall Holes
It's a 64. This is super helpful, thabk you very much. This is how I acquired the truck lol
Old 12-17-2014, 07:35 PM   #4
3/4ton Randy
Re: Firewall Holes
Yes, that is super helpful. My truck came disassembled and I am just starting the wiring. Thanks!
3/4ton Randy is offline   Reply With Quote
Old 12-17-2014, 07:37 PM   #5
KVB
Re: Firewall Holes
Ditto on the super helpful. Thanks
KVB is offline   Reply With Quote
Old 12-17-2014, 07:55 PM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Firewall Holes
Oh your good, Jon!
Old 12-17-2014, 10:45 PM   #7
racecougar
racecougar's Avatar
Re: Firewall Holes
I made this up a while back for threads just like this one. This was what each hole was used for on our '65 C10.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 12-17-2014, 11:03 PM   #8
jonzcustomshop
1961 crewcab
Re: Firewall Holes
ha! even better than mine, after looking at this I see where my mistakes were...
we should submit this thread to the faq!
Old 12-17-2014, 11:05 PM   #9
Mjminino
Re: Firewall Holes
Old 12-18-2014, 05:22 PM   #10
forestb
forestb's Avatar
Re: Firewall Holes
has anyone made one of these for a 63?
forestb is offline   Reply With Quote
Old 12-18-2014, 06:17 PM   #11
ray_mcavoy
Re: Firewall Holes
Excellent diagram!!
A few things I noticed that are different on some trucks:
(1) I think the hole labeled choke cable was only used with inline-6 engines. Dad's '66 (with a 283) has a firewall insulation retainer filling that hole.
(2) The V8 choke cable goes through the same hole as the oil pressure line (using a multi-hole grommet).
(3) When equipped with a factory tach, the wire leading to the coil also goes out through the same hole as the oil pressure line.
And while we're on the subject of firewall holes, does anyone know the factory location for the 3-speed overdrive lockout cable? Did GM run it through a pre-existing hole (such as along with the speedometer cable) or did this option have it's own hole drilled somewhere else in the firewall?
ray_mcavoy is offline   Reply With Quote
Old 12-18-2014, 11:48 PM   #12
Micmac
Micmac's Avatar
Re: Firewall Holes
You guys never cease to amaze me! I downloaded for future reference.
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 02-16-2015, 05:28 PM   #13
LVPhotos
LVPhotos's Avatar
Re: Firewall Holes
Bringing this one back. Filling holes and want to know if the blue hole has a grommet as all my stuff runs through it. Relized the two hole grommet is choke and oil or Throttle cable. Yellow is throttle arm and mount hole. Green is rear wire harness. Orange is unused and filled.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 02-16-2015, 06:16 PM   #14
frankslagoon
Re: Firewall Holes
Originally Posted by ray_mcavoy View Post
Excellent diagram!!
I ran my O/D cable down the speedo cable hole but maybe someone has a truck that came stock with O/D.
frankslagoon is offline   Reply With Quote
Old 02-16-2015, 07:11 PM   #15
racecougar
racecougar's Avatar
Re: Firewall Holes
The hole with the blue arrow pointing to it looks to me like it could have been added by a previous owner.
Old 02-16-2015, 07:21 PM   #16
Mjminino
Re: Firewall Holes
That's what I was thinking.
Old 02-16-2015, 08:44 PM   #17
LVPhotos
LVPhotos's Avatar
Re: Firewall Holes
I just filled it. I figured I can make a smaller hole with grommet. Not that many would know I filled a ton of holes anyways. Welding away today.
Old 02-16-2015, 08:59 PM   #18
frankslagoon
Re: Firewall Holes
my 63 doesn't have a "blue hole" either.
Old 02-16-2015, 10:09 PM   #19
Mjminino
Re: Firewall Holes
Rock on then
