Old 12-17-2014, 06:40 PM   #1
Crazy
Dead truck
Was driving my 71 C20 and it died when i finelly got it home i noticed the live wire to the choke was off would this be the cause.
Crazy is offline   Reply With Quote
Old 12-17-2014, 06:52 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Dead truck
Need WAY more info.
Do you have HEI (my first guess is a dead ignition control module).
Are you getting fuel?
Are you getting spark?
Does it turn over?
Is it making noises when turning over?
Does it sound different when turning over than it used to (like sounds like it's spinning faster - broken timing chain.)
No, a wire off the choke shouldn't cause it unless it shorted something out.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-17-2014, 07:33 PM   #3
TheSeeker
Re: Dead truck
Yea, if the truck was warmed up enough the wire coming off the choke wouldn't have made it die? Unless the choke snapped shut or something. Can you take the air cleaner off and see the choke butterfly closed?
Where you sitting at a stoplight or did it die under load? braking? etc.
TheSeeker is offline   Reply With Quote
Old 12-17-2014, 07:39 PM   #4
Crazy
Re: Dead truck
Died at a stop light.
Old 12-17-2014, 07:41 PM   #5
Crazy
Re: Dead truck
REDNECK
Do you have HEI (my first guess is a dead ignition control module). Not sure what this is.
Are you getting fuel? Yes i replaced the fuel pump anf you can see it in the filter and smell it.
Are you getting spark? Yes truck eventully started back up and im driving it again now
Does it turn over? Yes.
Is it making noises when turning over? No
Does it sound different when turning over than it used to (like sounds like it's spinning faster - broken timing chain.) No
Old 12-17-2014, 07:42 PM   #6
Crazy
Re: Dead truck
It only seams to do it when i i drive it for a long distance the t-stat is new and im not over heating.
Old 12-17-2014, 08:31 PM   #7
haysonj
haysonj's Avatar
Re: Dead truck
If that choke wire was fused you probably burned the fuse and your choke will not pull off so it will be too rich when warmed up.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 12-17-2014, 09:59 PM   #8
davischevy
davischevy's Avatar
Re: Dead truck
If it runs when cold, and dies after driving a while, then starts when it cools off, it's most likely the coil.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 12-18-2014, 03:27 PM   #9
Crazy
Re: Dead truck
Where is this coil you speak of. Yea it runs good but whe nit gets hot it sputters. And the gas seems to just cook off when im at a light. When it died yesterday i took off the filter and smoke was comming out the carb.
Old 12-18-2014, 04:19 PM   #10
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
Re: Dead truck
Coil location depends on if you have an hei or points style distributor.
Do you have 8 or 9 plug wires coming off the top of the distributor? 8-HEI 9-traditional, the wire that doesnt go to a spark plug goes to coil.
Is there a large square thing in the top of the distributor cap? If yes then you have HEI and the square thing is the coil.
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 12-18-2014, 04:20 PM   #11
Bagd72Chevy
C10 Collector
Re: Dead truck
Also it could be a coil or it could be vapor locked if your fuel line is running to close to the head/manifold. When it dies does it still have spark?
///Ryan
1971 Blazer - Rusty
Old 12-18-2014, 04:25 PM   #12
Crazy
Re: Dead truck
Ok so iv got an HEI and yes still has spark. Just hell to start have to let it cool for a bit.
