Old 12-17-2014, 07:02 PM   #1
63fleetsideC10
What is it??
Hello all, I'm trying to figure out the code for my engine. It's a 230 I think but the suffix code is confusing me. The cast number is 3921968 but the code is F0610PP. From what I've seen it should be a 283 V8?
63fleetsideC10 is offline   Reply With Quote
Old 12-17-2014, 08:29 PM   #2
pimpston65
pimpston65's Avatar
Re: What is it??
is it a inline or V? inline has casting #'s behind the push rod cover V's have it on the pass. side forward the #2 cylinder pad.
pimpston65 is offline   Reply With Quote
Old 12-17-2014, 10:12 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
Re: What is it??
Give me a year of the truck and if its a v8 or a straight 6.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-17-2014, 10:15 PM   #4
63fleetsideC10
Re: What is it??
The truck is a 63 so I don't know if the motor is original and it's an I6
Old 12-17-2014, 10:17 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Re: What is it??
Are there 2 side covers and are they 4 or 6 inches tall?
Old 12-17-2014, 10:36 PM   #6
jayoldschool
Moderator
Re: What is it??
It's not F0, it's FO. Look at the difference between the second and fifth characters.
jayoldschool is offline   Reply With Quote
Old 12-18-2014, 04:42 AM   #7
Coltronist
Re: What is it??
Yeah that's a 230, I had one with the same casting ID, if you really want to make sure, pull the valve cover off and check the Cylinder head ID, should be somewhere in between the rocker arms
Coltronist is offline   Reply With Quote
