12-17-2014, 08:47 PM | #1 |
2'' lift ???
Hi all, was thinking of lifting my 72 Jimmy 4x4 slightly, around 2 inches in the front and maybe a little more in back. Just curious what brands others have used and how they liked them, really want to keep it driveable, its all stock now, 106,000 miles on the truck so don't think springs need re-arched just think it needs a little height to look right. I looked thru some posts but they where mostly older and just wanted a fresher opinion. thanks.
12-17-2014, 10:21 PM | #2 |
Re: 2'' lift ???
I put a 2 1/2" Skyjacker lift, on my blazer when I first built it.
Eventually went to 6". The small lift rode great. Still easy to get in and out of. It comes with a 4" spring for the rear, to level the blazers/jimmys stance.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
12-17-2014, 10:39 PM | #3 |
Re: 2'' lift ???
Thanks, it definitely needs to be leveled out in my opinion, but I know a lot of people like the stock stance.
12-24-2014, 08:07 PM | #4 |
Re: 2'' lift ???
My 72 Jimmy came with a tow package positive leaf (one more than standard) up front and a extra leaf in the back and it sits about two inches higher than one without tow package.
12-27-2014, 01:36 PM | #5 |
Re: 2'' lift ???
Next set I'll be buying will Be Alcan springs. They give you the normal spring ride of stock But with the lift you want it to Have. I'd give them a call directly or call off road design for them to Build you a set. I've heard they ride the best out of all aftermarket springs but are more expensive. But for the ride quality from people that have them they say it's worth it.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
12-28-2014, 09:03 PM | #6 |
Re: 2'' lift ???
I used a 2 1/2 inch spring lift from tuff country and it rides great and fit 33x12.50 15s with no rubbing and a nice stance.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
12-29-2014, 11:02 AM | #7 |
Re: 2'' lift ???
Thanks I'll research Alcon, hadn't heard of those. thanks for the input just looking for different options, what other people have used and how they like them.
