700r4 TV cable issue
Anyone have any good recommendations for a 700r4 TV cable. I installed a B & M cable specifically designed for GM 700r4 transmissions, but the cable binds and wont get to Wide Open Throttle, no matter how I adjust it. Think the length of the cable is too short.
67' C10 Stepside SWB - 350/700r4 |
Re: 700r4 TV cable issue
You may have a throttle lever issue. There is a kit to install the cable stud in the correct radius, for some carbs. It sounds like your stud needs to move closer to the throttle shaft. This will match the throw of the lever to the range of motion available from the cable.
Scotty Baccus |
#3 | |
I can't see the cable being too different of a length. Small block or big block, the distance between the connections can only be about an inch difference. I'd recommend looking at the tv made ez kit from bowtie overdrives. I used their stuff with zero hassle, I have free movement from idle to WOT.
![]() Join Date: May 2013
Depending on what carb you have , you must get the appropriate tv bracket that bolts to the throttle plate on your carb , a bracket for the tv cable , and a stock tv cable works fine from a gran national . Summit has these parts , the cable must be fully out went the carb is at WOT .
Bowtie overdrive makes great products allso must read http://www.monstertransmission.com/7...ons_ep_62.html some links to ponder http://www.phoenixtrans.com/faqs/
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
![]() Join Date: Dec 2012
I had some issues with my 700R4 cable in the past. Someone stole the carb and broke the old cable instead of cutting or removing. I found a universal adjustable cable from TCI. I installed it through a couple of cable eyes that bolt to the bell housing just to guide it from the headers. One note on the universal cable, you do not use the stock cable seal with this cable. It has an O-ring.
Made a bracket from one I found. It had throttle cable and TV cable holes. I cut the throttle cable part off. Then put the TV cable in and adjusted it properly. I then set up a switch to enable/disable the converter lock. It worked well but was a pain to lock unlock it and remembering when to do that. Next step was an adjustable N.O. vacuum switch to do this for me. Then it would search and go in and out of lock. I built a simple circuit to delay from 3-10 seconds depending on the setting. I landed on 5. It now works great. Sorry I don't have better pictures but if you'd like and think they would help I can get under the hood and take some. Best of luck
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#7 | |
This is from another thread where we were discussing this very issue....
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
There are at least 2 different lengths of TV cable for 700R4. The carbureted ones are 1 length, the Tuned-Port ones are another. Not sure about TBI, probably same as a carb.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() Join Date: Sep 2005
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
also going to move this to engines and drive train for more coverage
I had nothing but trouble with mine till i put the tv made ez kit from bowtie overdrives took about 2 adjustments to get it right. Thats the only way to go.
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
Thanks to everyone for their input. Happy to report that after following the directions from the post above from no1udknow, I finally got to WOT!!! On a completely separate note, just ordered new exhaust manifolds from Classic Industries today. As soon as they come in, they are going on along with the new Magnaflow dual exhaust - Merry Christmas to me!!
1967 Chevy C10 Stepside SWB - 350/700r4 |
#13 | |
I love this site, so much knowledge. Thanks everyone!
