Old 12-18-2014, 09:19 AM   #1
jesdude7789
jesdude7789's Avatar
2005 5.3/4l60e into 1987 GMC
I walked into a salvage yard a few weeks ago and they had just gotten a wrecked 2005 Tahoe. I made a deal for the engine pull-out with harness, accessories, tac module, air intake with maf, etc.
My 1987 GMC R1500 truck has the dual gas tanks but I only use the driver side tank since the passenger pump has been dead for a few years now. The small block TBI engine died in it at the beginning of November and I'm really hoping to have the swap done by the end of January or early February because the truck is stuck in Austin at my brothers house (in his way) and I live in the Houston area so it's not the easiest project to make progress on since I have to drive back and forth on every weekend possible and with thanksgiving, Christmas, new years, etc. I have been juggling family stuff too.
Is there somebody with a truck just like mine that did a budget minded build that can help me figure out the right stuff for me to buy? I'm having trouble figuring out the exact fuel system components and adapters I need and do I have to replace the in-tank pump or can I leave it there and just add an inline pump to boost the fuel pressure? I only ask that because I need to get this running and anything that speeds up the process (like not dropping the tank) would be great so I can get this truck back home where it will be much easier to work out the details later.
I also need to know which exhaust manifolds will clear my frame without modifying it. I saw the cast iron hooker manifolds for 300. I would like to keep the factory stuff if possible though. I was looking at 2010 Camaro manifolds that come with the cats and I was thinking that would good since I won't have to fabricate all the exhaust piping myself and weld in o2 bungs and such?
[/I]
jesdude7789 is offline   Reply With Quote
Old 12-18-2014, 03:12 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 2005 5.3/4l60e into 1987 GMC
Clinebarger did an 85 suburban back when it wasnt cool to do this swap.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-18-2014, 05:03 PM   #3
jesdude7789
I tried searching his threads and could not find that.
Did he do a write up on it?
As of right now I have the 5.3 on a stand and I ordered the dirty dingo engine adapters. I plan to modify the harness myself and I need to find a good place in Austin to source the transmission, torque converter, and bolts from. I would like to find a really low mileage unit or a fresh rebuilt unit because I want to be sure that I won't have tranny problems for years.
Old 12-19-2014, 12:48 AM   #4
oldman3
oldman3's Avatar
You can check out Glocks build, but I'm telling you now it's 76 pages long, but it should have everything covered you want. Here's the link http://67-72chevytrucks.com/vboard/s...d.php?t=350986 ...Jim
oldman3 is offline   Reply With Quote
Old 12-19-2014, 02:06 AM   #5
scottybaccus
scottybaccus's Avatar
I did my '87 GMC a few months ago. You can look up my shop on FB for pics and some details. I can walk you through every aspect.
I am in Pflugerville, a suburb of Austin. You're welcome to come see mine. I can hook you up with anything you might need.
Scotty Baccus
scottybaccus is offline   Reply With Quote
Old 12-19-2014, 08:45 AM   #6
homemade87
Jesdude , I see you got the tach module . If you did not get the gas peddle I would go back and get it . All peddles are not created equal . You have to have the right one for it to work . You will have to modify it to work in your truck .
Also I have no tried them but some has said the trailblazer ss stock manifolds will work . They hug the block closer .
homemade87 is offline   Reply With Quote
Old 12-19-2014, 09:36 AM   #7
Clyde65
Clyde65's Avatar
jesdude, he doesnt have a build thread, he did his 'Burb in 2004 I believe. Hit him up, he can tell you anything. he does these swaps for a living.
Clyde65
Rebuild of Clyde
support our troops!
Old 12-20-2014, 01:32 AM   #8
slotard
I'd really like to do something similar sometime, but I've got an older C20 and would be very tempted to go with a 4L80E so that I could add a snail or two sometime down the road.
Do you need to smog/inspect it?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 12-20-2014, 11:23 AM   #9
jesdude7789
That would be great to come check it out Scotty. I can certainly do that. I'll be in Austin next weekend from Wed through Sunday.
I appreciate the help. I will start reading!
I did make sure to get the gas pedal and the harness from it to the tac module.
I will pm him shortly. Thank you.
I don't have to pass emissions anymore here in Galveston county.
Old 12-20-2014, 08:09 PM   #10
ls1nova71
ls1nova71's Avatar
Please don't take this the wrong way, but this sounds like your first swap? If so, my suggestion would be to get the truck back to your place before trying to swap the engine. You're looking at driving over 175 miles one way to work on it, and you almost will never be able to do this swap in a weekend on your first try. Spend the money to get the truck towed to your house where you can actually work on it without having to worry about forgetting a part, or tool, or being rushed since that is going to add to your problems. From what I have seen and read about people who have problems with these swaps, it's generally because they skimped on something here or Micky Moused something there, thinking they would go back and fix it later, only to have it bite them in the ass before 'later' arrived. Trust me, there WILL be road blocks you just won't be prepared for, no matter how prepared you are for them. I'm not trying to rain on your parade, just trying to be the voice of reason. Sure there are a lot of internet "keyboard mechanics" that say this is a piece of cake to do, but it's relative to your skill level, and familiarity with the swap, and for a first swap, you would probably be way better off doing this at home and at your own pace. Again, I'm not trying upset you, just my $0.02.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-20-2014, 11:04 PM   #11
jesdude7789
I don't mind the drive because I enjoy visiting my brother in Austin every couple of weeks anyway. I'm not going to rush anything though. I am a somewhat meticulous person and think ahead constantly with my projects. I don't have the option of towing it back to where I live because I do not own a house or any type of place to keep it while I do the work. My brother has a three car garage with matching driveway space and it's well suited for the task. My engine hoist and other tools are already there as well. I appreciate the concern. I do have an automotive education as well as electronics experience. What i don't have is extensive knowledge of this particular swap as I never planned to do this before and I'm just on a tight deadline now that I have to do it. Thanks again
Old 12-21-2014, 12:34 PM   #12
ls1nova71
ls1nova71's Avatar
Ok, well I guess I'm just a little confused because you contradict yourself in some posts. In your first post you state that the truck is in your brother's way, and it will be easier to work on when you get it back home, so that's why I suggested just getting it back before you start.
Anyway, if you are going to try to do it there, you are REALLY going to have to do more homework than most people do, so you don't drive all the way there just to find out you cant do "this" before "that", and you can't do "that" because you don't have part "X", do you see where I'm going? I would spend A LOT of time on here reading through build threads and seeing what others have done. I would look at all different kinds, not just square body builds because a lot of info can be gained from different types of trucks, and the more options you have on doing any given task, the better off you're going to be.
That said, I'll answer your question in the first post. Swap out the intank pump. I would get a Walbro255 or something similar, and either drop the tank or slide the bed back enough to get to the sender. The reason is you CAN'T pull fuel through an intank pump with an external pump, you'll burn the pump up because of the restriction.
Old 12-22-2014, 08:42 AM   #13
jesdude7789
Sorry that was my fault. What I'm trying to say is that I don't mind going to Austin every other weekend to work on it, but also it is in my brother's driveway and he already has a project vehicle of his own and so I want to get this done as soon as possible so that we can work on his projects (He has woodworking stuff to do) whenever I come visit. I also just need the truck to be back up to it's daily driver status because my spare vehicle is much more worn out and I'm just lucky it hasn't broken down yet.
This next weekend I plan to modify the wiring harness and get the ecm sent off to be programmed. I'm not doing any cam swap stuff or anything like that. The guy says that his stand alone tune is a basic performance tune so I'm fine with that. This engine will still make over 100 hp more than what I had so I know i'll be very happy with it.
I'll also get the dingo mounts prepped and painted and start disconnecting everything on my truck in preparation for the swap. We may or may not pull out the old engine this weekend. It depends on my brother and his work schedule and any family duties he might have.
Thanks for clarifying on the fuel pump. I mainly asked that question because I have worked on 80's ford trucks and they had low pressure pumps in the tanks and then a high pressure pump on the frame rail. I thought I might be able to do the same thing temporarily.
As of right now, My goal is to have this swap up and running by the end of January.
Old 12-22-2014, 09:40 AM   #14
jesdude7789
From what I understand so far, I should be able to use just the dirty dingo adapters and then position the trans on my existing crossmember.
Will the factory driveshaft slip right into the tail housing of the newer trans without any issues?
Can I use a single fan or do I need dual fans? What cfm rating?
Old 12-22-2014, 11:48 AM   #15
ls1nova71
ls1nova71's Avatar
I suppose you could run two pumps, but you have to buy a pump anyway, so I would just go with one intank pump. Otherwise if the original intank pump dies, then you have to buy another pump. Seems like doing it right the first time would be the way to go.
On the driveshaft, I assume you have a 700r4 in it now? If so, then the yoke will fit a 4l60e. If you put a 4l80e in it then you will need a different yoke.
As for the fan, one would most likely be enough, but you can never have too much. I would look at Taurus or Windstar fans in the junk yard. They're cheap and move a lot of air. Or if you can find a 4th gen Camaro dual set up, that would probably fit your radiator pretty good.
Old 12-22-2014, 12:57 PM   #16
jesdude7789
I do wish I could change to an external pump altogether but you are right about making it too complicated with extra pumps and such as well. Maybe one day I will convert to the suburban tank setup and make an access panel in the bed floor. I will order the walbro intank pump.
I do have the 700r4 so that is good news!
I found some pictures of the Camaro setup and that looks pretty good to me. I will start searching for that one.
Old 12-22-2014, 11:42 PM   #17
jesdude7789
I scored a set of 2010 camaro exhaust manifolds along with the few feet of piping from each side so i have the o2 sensor holes and cats. I am thinking that I will trim the piping just after the first o2 holes and see if I can match it up to my truck's factory y-pipe.
Old 12-29-2014, 02:12 PM   #18
jesdude7789
I was able to remove the three broken exhaust bolts with my trusty welder
Sent the ECM for reprogramming and should have it back next week. Picked up a Bosch fuel pump to swap into my tank.
Old 12-29-2014, 03:17 PM   #19
scottybaccus
Just like I promised?
You still in town?
Scotty Baccus
Old 01-12-2015, 10:47 AM   #20
jesdude7789
You still in town?
Oh yeah, just like you said! I was in town but I had a friend in Austin unexpectedly call me Friday morning and offer his help so we were able to knock out a lot more than I anticipated. Help is difficult to get so I needed to take advantage of that. We started the removal of the old engine and disconnected everything and started to remove the engine with my hoist whenever it had a failure and prevented us from finishing. So this weekend I will head back and I have to fix the hoist first and then my friend should be able to come back and help me finish the removal.
I hooked the starter up to my 5.3 and cranked it over a few times at least and it was nice to see and hear that. It sounds like it has good compression and I will do a comp test this weekend just for kicks.
Old 02-10-2015, 10:05 AM   #21
jesdude7789
Got the 5.3 bolted in! I was pretty happy to see it sitting in it's new home after all the work so far
I still have a lot to do though. Working on my harness mods, need to buy a new radiator, hoses, trans lines, hook up the new fuel lines, drop the tank and swap the pump out, figure out where I'm getting vacuum for the brake booster, a/c controls, etc...
This came from an 05 Tahoe with electric fans but I think I want to use a mechanical fan for simplicity right now. The water pump pulley has the threaded portion on the snout so I can just get the mechanical fan from a pick-and-pull and bolt it on??
Old 02-10-2015, 10:33 AM   #22
scottybaccus
See if this helps.....
LS Swap Guide
Scotty Baccus
Old 02-17-2015, 04:52 PM   #23
jesdude7789
LS Swap Guide
There is some great information in there Scotty! Thank you for that link.
I didn't get to make as much progress as I wanted this last weekend.
Installed the Intake manifold after cleaning up the ports and gasket (still in great shape), alternator and power steering, serpentine belt, 2010 Camaro exhaust manifolds with new ac delco gaskets and the Dorman bolt kit. I didn't torque those bolts to spec just yet because I want to wait until I'm sure I don't have to remove them again for any reason. I may have to adjust the engine adapter brackets again and I would want the exhaust out of my way for that.
Old 02-17-2015, 11:37 PM   #24
mattcrp1
mattcrp1's Avatar
Looking good.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-23-2015, 04:10 PM   #25
jesdude7789
I'm frustrated with the dirty dingo engine mounts. Why did they make them where you CAN'T have the engine all the way forward in the slots? I have no clearance between the steering link bar and the oil pan!
I really didn't want to have to modify my trans cross-member and shorten the driveshaft....
I also was trying to figure out how to route my trans cooler lines since I definitely can't route them underneath the engine. I don't like trying to route them around the starter. I'm playing with the idea of running them along the top of the passenger frame rail but above it a couple inches and also about 2 inches from the exhaust header. I'll make a little support piece somewhere to hold them up and it's a straight shot to the cooler that way. The piece of tubing in the picture is the old one and it looks like crap since I'm just using it to get an idea of routing
