8 lug to 5 lug rotor
I want to switch my 78 3/4 ton into a 5 lug bolt pattern can I just switch the front rotors or do I have to switch spindles too? Thanks Telly.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 8 lug to 5 lug rotor
Spindles need switched too. Which leads to swapping lower control arms since the half ton ball joints are too small for the ball joint hole in the 3/4 ton lower arm. It kind of becomes a pain to piecemeal it all together. It's much, much easier and likely cheaper to just buy an entire 1/2 front end and swap the arms, steering, spindles, everything.
Crap! Thanks for the info.
The last one I bought was 150 off of Craigslist. That got me an entire frame cut off from a half ton Suburban. You get every single little widget you will ever need all in one package.
At the body shop.
Or get 1/2t spindles reamed to 3/4t ball joints.
And maybe chang rubber flex brake line. I know 1t is different not sure about 3/4t
" That didnt make it any newer " " Dont antique the equipment " |
I have a set of Detroit steel wheels that I want to put on this, I already have dropped spindles on it I may just have to sell the wheels and try to find something else.
67-72 parts collector,…
![]() Join Date: Nov 2002
www.earlyclassic.com sells a conversion drop spindle to do exactly what you want.
Bolts on your 3/4 ton truck and used 1/2 ton rotors and calipers.
