08-19-2003, 10:31 PM | #1 |
Drive it like U stole it
okay another stupid grill ?
I have started polishing this shell and its looking good but there are some lite scratches in the aluminum , Can I take some 600 or 1000 grit sand paper and wet sand them out ? I know sound like a waste of time but I will post before and after pics when I 'm done . Thanks
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
08-19-2003, 10:33 PM | #2 |
Yes, you can wet sand them out..... start with 400, then 1000, then 1800 and then you can polish with mothers or whatever metal polish you like. I use blue magic.
08-19-2003, 10:41 PM | #3 |
I'm using blue magic and it is awsome . I tried mothers to start out with but had no luck . I bought the blue stuff today and when i got home I tried it out .WOW great stuff . Thanks
08-19-2003, 10:51 PM | #4 |
its all about the +6 inches
where can we find this blue magic, and what will it set me back?
08-19-2003, 10:54 PM | #5 |
I work for Advance auto parts and we carry it . I paid les than 4.00 for it . It works best on a small buffer for what Im doing
08-19-2003, 11:12 PM | #6 |
Cool, it is affordable too!
Guess I'm stopping at Advance Auto on the way home from work tomorow. |
08-19-2003, 11:27 PM | #7 |
Blazerless:-(
I got my blue magic at Schucks- polished up my windshield trim like "MAGIC"
08-20-2003, 12:56 PM | #8 |
Mike
I never used blue magic till a year ago.A place going out of buisness had some.I bought 1can.Liked it so well I bought the other 14 cans!
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
08-20-2003, 05:00 PM | #9 |
Now the others dig........
Sorry to butt in, but how does one polish aluminum trim., can I buy a buffing wheel that can be used on a drill??? Including the blue magic, what else would I need, my 68 grill trim and bezels need some polishing. How long will a good polishing last???
thanks!! -Roger
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
08-20-2003, 09:32 PM | #10 |
I dont know about plastic but on metal or aluminum you cant beat it. It was voted #1 by consumers
08-20-2003, 09:37 PM | #11 |
You can polish plastic with it too. I've even used it to get small scratches out of paint jobs.
08-20-2003, 09:55 PM | #12 |
I did my 1970 outer shell a few years ago. I worked the
cad coating off and polished the aluminum. When you get it a shiney as you want, buff it off with clean paper towels until there is no black left showing on the paper. Do not let your bare fingers touch any of the shiney area. It can now be coated with clear lacquer or Krylon gloss clear. I have used Krylon clear on other items and it seems to look better than the lacquer. I have had good luck with polished steel; brass and copper. If you take fresh blasted cast iron and coat it with Krylon satin clear, it will keep the fresh blasted look for years. I use about three heavy coats so the pores will fill. I have not done this with any parts that are under a hood but on antiques such as fireplace irons and saws. Has not rusted in 15 years. EdB |
08-20-2003, 10:14 PM | #13 |
Thanks for the tip EdB. I was wondering how I was going to keep it looking shiny
08-20-2003, 10:19 PM | #14 |
here a pic of it while it was in its resting place
08-20-2003, 10:55 PM | #15 |
Large Member
If people out there dont have any of the stores listed in this thread that has Blue Magic, go to just about any truck stop.
08-20-2003, 11:38 PM | #16 |
theres a truck back in there in that pic?
70 longbed 496/th400/Ford 9" |
08-24-2003, 02:32 AM | #17 |
Anyone ever try Wenol Polish?
Work pretty good, they have two different stages of polish depending on what condidtion the metal is in. Blue Magic sound like its worked for a few, may have to give it a try.
Jimmie Modern Vintage Autoworks - '70 Chevy C10 - '74 Chevy C30 3+3 Dually - '04 Chevy Colorado Built, NOT, Bought. If you build it...they will ENVY! Drive Slow, Scrape Hard, or Take Your Truck and GO HOME! |
08-24-2003, 02:21 PM | #18 |
Picked my Blue magic @ walmart, or custom wheel shop. I also use it with a buffing wheel and a drill. Use a good drill and dont work it to hard, to keep from burnning it up your drill. Also be carefull around the edges of the wheels or what ever your polishing becaues the drill will like to jump and then you just have to sand out another ding and start again. Good luck Seth
97 ext cab 4x4 04 pontiac grand am 05 honda rancher AT (yellow) 71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter |
08-24-2003, 09:02 PM | #19 |
18436572
I'd recommend a final sanding of 1500 wet. The finer you sand the easier to buff and not to mention a kickass finish.
08-25-2003, 01:40 PM | #20 |
http://www.perfectpolish.com/
I have one of those campers. Mine will be that polished by next year. That's the stuff to mirror AlCad aluminum.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
08-25-2003, 02:50 PM | #21 |
will this blue stuff work on rough aluminum surfaces? the slots of my aluminum wheels are pretty rough, but i was thinking of sanding them down, and trying to get a shine out of them --- make them look like chrome. do i need to sand first, then use this blue stuff? or will it polish rough surfaces?
thanks! jewels.
68 C10 Red Step 350 my first child & main focus 58 3200 Apache LWB Step the upcoming project |
08-25-2003, 04:39 PM | #22 |
Progress = 0%
Jewels: If you buy some of that Blue Magic, be sure to hide it from your mother........ she might try to sell for $0.10 when you aren't around!
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
08-26-2003, 10:44 PM | #23 |
update
well as you see in the before pic the grill looks hopeless .
the dent you see in the before pic is almost gone and I have started sanding and polishing . just a few more dings and try to work longer than 20 min. at a time and she should be done soon
08-27-2003, 07:56 AM | #24 |
Mike
Keep it up!I started mine yesterday.Just stripped the anodizing off.Will start to polish today.
08-27-2003, 08:51 AM | #25 | |
