Old 12-18-2014, 08:55 PM   #1
fokker
71' rear coils
just orders some rear drop coils for my 71 c10. Question is how hard are these to install? Any tips or tricks?
fokker is offline   Reply With Quote
Old 12-18-2014, 09:15 PM   #2
JonnyC10
Re: 71' rear coils
Very easy. I ordered new cups and bolts when I did mine. I cut the springs and old bolts off so I didn't have to mess around with them. First I put a big jack stand on the frame rail under the cab and then jacked up the rear diff and put a small stand under it. Then I put the jack under the trailing arm to support it. Then I cut off the old u bolt. Cut the spring and bolts to remove the spring retainer cups. Install is reverse of removal. Repeat for other side.
JonnyC10 is offline   Reply With Quote
Old 12-18-2014, 09:18 PM   #3
fokker
Re: 71' rear coils
I ordered the new cups and bolts as well. What is the point of cutting off the u bolt? The truck currently has 2" blocks as well.
Old 12-18-2014, 09:20 PM   #4
JonnyC10
Re: 71' rear coils
Mine was old and rusty. Lol. I just ordered new everything.
Old 12-18-2014, 09:22 PM   #5
JonnyC10
Re: 71' rear coils
When your done, make sure your rear brake lines and stuff aren't rubbing on anything. Mine was hitting my exhaust and I just had to bend the line out of the way.
