12-18-2014, 11:20 PM | #1 |
pitman arm differences
I have a late 67 C-10 with the dimpled frame that has a power steering box that is worn out. A friend is parting a 64 C-10 with a 76 C-20 steering box. What pitman arm will I need to buy of will this even work?
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
12-19-2014, 01:01 AM | #2 |
Re: pitman arm differences
It'll bolt right on, and probably the arm on the 67 if you still have drum brakes, unless already converted to disc then either will work
