Post Whore
![]() Join Date: Aug 2014
Trouble filling the tank with gasoline.
Now that I am getting to drive my '74 GMC "Wideside" more I am having difficulty pumping gas in it. The tank acts as if it was full even though I know she needs gas. So I have to gently squeeze the handle not all the way or it will overfill, it's a major pain to even put 5 gallons in. I try pushing the nozzle all the way in, I try holding it all the way up or all the way down, I can't seem to figure it out.
Do you guys have any idea what it can be? |
![]() Join Date: Jun 2009
Re: Trouble filling the tank with gasoline.
Modern nozzles aren't user friendly with the old trucks. I have pretty good luck turning it upside down to fill it but you have to hold it the whole time and can't walk away
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
I have the same problem. I'll be watching to see if anyone posts a solution.
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles 91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles 96 K15 Sub 350/4L60/243c/10 bolt 333k miles |
It's whatever works, doesn't seem to be a magic bullet fix, short of a late model tank and piping. IMO, the pump also plays a role. One station I use, there are a couple pumps that my truck has issue with, Other pumps, same station, no problem. Then again, this is not a "set it and forget it" deal. Sometimes, if your not holding your tongue just right, it would be quicker to fill a gas can, then dump that into the truck...
All the way in, halfway in, half throttle, upside down, sideways... I just consider this a quirk of owning an older truck. What irritates me is the pumps don't have enough hose to reach the other tank. Have to flip the truck around to fill both tanks.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
Can't edit. Above is with the caveat that your vent is correct and piping in good shape. No PO "fixes" or mud daubers homesteading.
We have a 02 caravan we use for shop buggy at work
and fill up at the city pump in town have to hang that thing way out and put low? |
#8 | |
When I fill my lowered 84 I have to put the nozzle all the way in then pull It out 1 to 2 inches then press down on the gun part of the nozzle for my tank to fill worry free. I've never had a problem filling it that way. I've even got a new vent and good piping and it still has a problem where you have to leave an air gap with the nozzle to vent itself.
Not sure if it will help you or not. I just know at the stations I always get looked at cause I'm crouched filling my tank with the pump gun half out. |
#10 | |
Roadside Rebuilder
I don't have much of a problem. But if I do, I just hold the silly fume-boot back with my left hand and hold the pump with the other. Despite Oregon having no self-service, the pump-jockey doesn't seem to mind. And if he does, I growl at him and tell him to get his hands off my pickup.
Also, I've driven semi-trucks for a living pretty much since I was a kid, so I'm in the habit of using my odometer as a gas guage and habitually calculating my fuel economy, so I have a pretty good idea how much fuel I'm going to need and I know when to quit trying to cram it in. Often, the employees don't know that, and end up spilling gas all over the side of my reasonably nice factory paint... I realize that's an Oregon-specific trouble, but keeping an eye on fuel-consumption is a good practice to get in, regardless of who fuels your ride. And if you're finagling fuel into a stubborn Squarebody, it can be the difference between a cold hike and a warm cab. That said, there seems to be some nozzles that like my truck better than others. The Chevron Station near my house is one such place. The fuel flows smoothly, the coffee is usually reasonable, and the gals behind the counter are easy on the eyes and dig my truck. Conversely, the Arco hates my truck, stews the coffee, and is ran by tweakers. Ah, the joys of having a 40 year old daily driver! Last edited by Oregoon; 12-21-2014 at 12:05 AM. |
#12 | ||
Post Whore
Pull your rubber back + good coffee + hot chics = smooth flow |
#13 |
DANG IT!
So I didn't have to pay the extra 500 to have my old fillers swapped to the newer style when I had the truck painted?? LOL |
#14 |
Roadside Rebuilder
PM me for the address. Oregon is a bit of a drive from Sac', but I'm only too glad to help out a fellow member!
#15 |
Oregoon- I work in SE PDX. Where is this Chevron you speak of?
#16 |
Roadside Rebuilder
82nd and Stark! It seems we travel in the same circles. My brother is building a house on Pihl Road, and you work over on my side of town. Banks to SE--that's a hefty commute and The Sunset is no fun! Whereabouts you work? Last edited by Oregoon; 12-21-2014 at 02:32 PM. |
#17 |
My formula that seems to work where ever I go is to turn the nozzle sideways and pull it out just a bit from fully seated. Then go full throttle on the filler until stops then find the sweet spot for filling speed. Works where ever I go.
#18 | |
I did blow out my vent line yesterday, so I'll post back any results the next time I fill it. Tank is full now so it will be at least a week. Driving it to work for the first time tomorrow |
#19 |
Active Member
![]() Join Date: Mar 2004
You shouldn't feel too bad, my '04 Colorado has developed the same issue. Hopefully neither of my squares do it, I don't know since they aren't really driveable at the moment.
#20 |
I'll be building a flatbed before too long and can easily swap the tank while I'm in there. Are there any tanks I should consider? My truck is a long bed, more fuel is better, but I might be shortening the end a little bit. I have the same problem with the tank as OP, it's slow to fill and likes to spill before it stops.
1973 C20, 350/350 |
#21 |
I have one truck that takes gas no problem and my other truck takes the gas very very slow. I am positive it is the vent or sending unit clog. When they work right they should take the gas as fast as you can pump it. They are both 76's
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
#22 |
Don't Crush em Restore em
I have an 1980 that the first owner punched out both tanks so he could put leaded gas in at the time. So mine has the same problems, I can never pull the handle all the way and pull the nozzle out of the tank a few inches then it seems to work pretty well. I do have two other filler necks that I have from the 87 bed that I put on my truck and someday when I can left the bed off again I will replace the fillers with the later model ones.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually ![]() ![]() ![]() ![]() ![]() ![]() |
#23 | |
If you are having this problem, I highly recommend blowing out your vent line. |
#24 | |
#25 |
Evap canister seemed fine. If anything came out, it went into the tank, since I blew it from the canister end.
