Old 12-19-2014, 08:26 AM   #1
Mjminino
1964 c10/c30
I have an opportunity to look at a 1964 C30 strictly for parts. I am no where near 100% on what is still available on it. If it still has the dually axle on it, what is all needed/modifications including hardware to bolt it up to my 1964 C10 short box?
Next question, specifically to this C30 are there any parts that I should definitely be looking at for rarity or of any value in y'alls opinion?
Thanks in advance,
Mike
Mjminino is offline   Reply With Quote
Old 12-19-2014, 09:18 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 1964 c10/c30
why would you want to put a dual rear end on your short bed half ton truck? Other than being different I mean.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-19-2014, 09:26 AM   #3
Mjminino
Re: 1964 c10/c30
You nailed it, i figure why not, it'd be a cool little 'mod'!
Old 12-19-2014, 10:25 AM   #4
TJ's Chevy
TJ's Chevy's Avatar
Re: 1964 c10/c30
Well...I'm sure there wouldn't be to many mods..other then changing drive shafts...and switching to leaf springs...sure would be neat.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 12-19-2014, 10:52 AM   #5
Mjminino
Re: 1964 c10/c30
I wonder if i could set it up to use coil springs and what not. Would just need to cut off old brackets and weld them to the dually axel
Old 12-19-2014, 11:15 AM   #6
PGSigns
PGSigns's Avatar
Re: 1964 c10/c30
Then cut your bed all up.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-19-2014, 02:19 PM   #7
jayoldschool
Moderator
Re: 1964 c10/c30
Don't forget top speed around 50mph...
jayoldschool is offline   Reply With Quote
Old 12-19-2014, 06:00 PM   #8
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 1964 c10/c30
either that, or source the spring packs, and brackets from the 1 ton, there is also a frame cross brace between the spring hangers.
