Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 12-19-2014, 08:45 AM   #1
biohazardbill
66 gmc 4000
So I have picked up a 66 GMC 4000. Long story short I am actually wanting to convert this to a more modern drivetrain to be able to use it as a car hauler for long distances and feel safe in doing so. Plan is to make it a ramp truck, not a rollback and possibly pull a trailer. I see 1 ton duallys all the time lately pulling ramp trailers with 3 cars ect so I figured using a 1 ton rear axle and maybe front end components would be the way to go. Thoughts?
biohazardbill is offline   Reply With Quote
Old 12-19-2014, 09:15 AM   #2
biohazardbill
Re: 66 gmc 4000
Old 12-19-2014, 09:17 AM   #3
68panelman
68panelman's Avatar
Re: 66 gmc 4000
Just remember the wheel openings are larger for the 20'' rims these trucks came with, most 1 ton rears are 8 lug and will only offer you smaller wheel choices. I would look into the GM 3500HD axles, you get disc brakes, 19.5 wheels, and will accept the 5/10 lug 20" wheels you already have.
68panelman is offline   Reply With Quote
Old 12-19-2014, 10:08 AM   #4
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: 66 gmc 4000
Nice truck.
Like the nice sheet metal.
If the "GMC" letters are original to the truck, it is not a '66, but a '64 or '65.
Can't help much on the modifications. If it were mine, I would be keeping it original, but either change the Rear Gears or possibly swap it to a more hiway-friendly 2-Ton Rear.
Or, check into a Brown-Lipe Aux Trans with an Overdrive.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 12-19-2014, 11:36 AM   #5
biohazardbill
Re: 66 gmc 4000
I actually thought the same thing but was unsure if the same applied to the big trucks when it came to the GMC lettering.
I doubt it will stay original drivetrain wise. The main reason I picked it up because I have always thought about having a ramp truck of the same time period as my suburban. I really wasn't ready for this yet but for the price I could not pass it up.
Old 12-19-2014, 07:54 PM   #6
mrolds88
Re: 66 gmc 4000
You could find a late model C4500 or C5500 and pull the drivetrain. Might get lucky and find a Duramax truck!!
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-19-2014, 09:34 PM   #7
Re: 66 gmc 4000
I see the perfect donor in the background. Gotta go medium duty in my book. Maybe you can buy a 1t and haul like that, but if you're going to build it, build it right. Just put the cab on the newer frame
