12-19-2014, 12:56 PM | #1 |
C4 Suspension Conversion
Anyone know of a kit for a C4 suspension on to an S10 frame? Or will we have to make everything by hand. I know there is a kit from flat out for the stock frame but they don't have it for the S10. Thanks for any help.
12-19-2014, 05:41 PM | #2 |
Re: C4 Suspension Conversion
From what i see your on your own. C4 is much wider you will need to fab your own stuff.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
12-20-2014, 12:11 PM | #3 |
Seems like you're creating alot of extra work for yourself- if you are going to use the C4, why not just keep the stock frame?
12-22-2014, 03:00 PM | #4 |
Well the stock frame we would need to box in because we all know it wasn't built to handle 400hp. But that is not a problem, boxing it in would be no worse than having to fab up the brackets for the S10 frame. I was just wondering if anyone had put the C4 Independent suspension under a S10 to get away from the leaf springs but not going full coil overs. Thanks for the input guys I appreciate it.
12-23-2014, 01:48 PM | #5 |
Get the Nerd Rods Frame. All C4 suspension, weld it yourself, bolt on frame.
1970 Datsun 240Z 1972 K5 Blazer Highlander 1972 Chevelle 1959 Apache 3100 SWB Fleetside 2006 VTX 1800f Build thread: http://67-72chevytrucks.com/vboard/s...ght=highlander |
