Old 12-19-2014, 06:37 PM   #1
MIKESAD50
Dash brace
Is there a dash brace that goes from the firewall to the steering column mount bolts? if so does anyone have a picture of the brace and one of it installed? also is it really necessary?
I have one that looks like it would be for that but it is slightly to long , or it is not the correct one.
Mike
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 12-19-2014, 08:06 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Dash brace
it is hard to get in and out and it is needed
here are some picture that show most of it
dwcsr is offline   Reply With Quote
Old 12-19-2014, 08:12 PM   #3
MIKESAD50
Re: Dash brace
Thanks Dave.
1950 3100 5 window
Old 12-19-2014, 10:24 PM   #4
Donaldo
Re: Dash brace
I think that brace is pretty much required, it not only holds the dash in place it also braces the steering column if it is attached to the dash - I suggest using it. 2 bolts under the dash, 2 bolts on the firewall are stock, or a good welder.
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 12-20-2014, 12:44 AM   #5
oldman3
oldman3's Avatar
Re: Dash brace
I kept my brace and attached it to a 1-1/2" angle I installed to tie the A pillar together when I removed the stock dash and installed another type. I also welded the two bolts going thru the firewall to the firewall, so it was smooth on the outside cowl firewall area. Here's couple pics showing the brace...Jim
oldman3 is offline   Reply With Quote
Old 12-21-2014, 08:53 PM   #6
J48chevy
J48chevy's Avatar
Re: Dash brace
Can you buy replacement dash braces? Not to high jack post but I need a replacement one and did not see in any of my parts books.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end.
http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670
J48chevy is offline   Reply With Quote
Old 12-21-2014, 09:40 PM   #7
crossfire84
crossfire84's Avatar
Re: Dash brace
I made my own, very easy.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 12-21-2014, 10:51 PM   #8
Donaldo
Re: Dash brace
Classic Ind. replacement dash ad states it comes with the firewall brace - you might call and ask them if just the brace could be available - or any of the replacement body part dealers - maybe....
Thanks, Don
Old 12-22-2014, 12:37 PM   #9
torchlight
torchlight's Avatar
Re: Dash brace
Agreed that this is a straighforward part to fab up yourself - here's what was done on my truck:
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 12-22-2014, 02:04 PM   #10
MIKESAD50
Re: Dash brace
I found it thanks to Dave's picture.
1950 3100 5 window
