Old 12-19-2014, 08:18 PM   #1
Benji
floor pan vender
I thought that I seen on the message boards that gmc pauls made the full floor pan for the blazers. All I can find is the full floor pan for the pickups. Has anyone bought the full blazer floor pan from somewhere else and used it? Just wanted to make a note of the new blazer/jimmy sheet metal products are for when I need them. Thanks in advance
Benji is offline   Reply With Quote
Old 12-19-2014, 08:26 PM   #2
briank
Re: floor pan vender
It may have been Wes at heartbeat classics that had it on the board.
briank is offline   Reply With Quote
Old 12-22-2014, 08:59 AM   #3
David623
I did not know anybody made one for the Jimmy/Blazer, I bought a cab floor and modified it to fit the Jimmy. Just recently put the tub on the frame and body mounts lined up great. Take plenty of time and do the layout. I built a rotisserie that replicates the frame body mounts and it worked great. good luck with your project.
David623 is offline   Reply With Quote
Old 12-22-2014, 01:31 PM   #4
richard2717
Equal opportunity joke ofender
richard2717's Avatar
I think this is the post you might have seen. It is the rear floor they are making now and they also have the step up now that is between the front and rear floor. I don't think they have a complete front floor yet
http://67-72chevytrucks.com/vboard/s...d.php?t=644322
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 12-22-2014, 02:50 PM   #5
pound41
it is available. I had my local vendor offer it to me after I had emailed about the pickup floor pan. He said 2 -4 weeks he could have me one. So it is out there. As soon as I get caught up I am getting one
pound41 is offline   Reply With Quote
Old 12-23-2014, 01:01 AM   #6
Benji
Thanks everyone. If anyone ends up getting one can you post the process you use. It would be a ton of help.
Old 12-23-2014, 10:35 AM   #7
briank
Southern Kentucky classics has them too.
Old 12-23-2014, 10:56 AM   #8
richard2717
hanks for the info Brian
Here is the link if anyone is looking
http://sokyclassics.com/product.php?skcid=1003768
Members I have met.
Old 12-30-2014, 10:11 AM   #9
GMCPaul
The Blazer cab floor pans advertised by So. Ky. Classics and others ARE NOT A BLAZER FLOOR PAN. They are the truck cab floor pan and have the raised area behind the seat for the in cab gas tank that is located behind the front seat in the truck. You will need to cut this area off that floor pan and then modify it to work with the Blazer. The actual Blazer cab floor pans are supposed to be out later this year but we do not currently have a date for them to be available as yet. Currently only the following complete Blazer / Jimmy parts are available.
1969-72 Blazer Jimmy Rear Cab Floor To Cargo Floor Step Up Plate ( used to join cab floor to cargo area floor )
1969-72 Blazer or Jimmy Bedside Assemblies*L&R
1969-72 Blazer or Jimmy Cargo Bed Floor Area
1969-71 Blazer Doors L&R
1972 Blazer Doors L&R
There are also different patch panels available for Blazer / Jimmy only
1969-72*Blazer / Jimmy Upper Windshield Header Repair Set
1969-72 Blazer/Jimmy Rocker Box L&R
1969-72 Blazer/Jimmy Rocker Box Cap L&R
1969-72 Blazer / Jimmy Rear Passenger to Cargo Section Step Up Plate For Drivers Side
1969-72 Blazer / Jimmy Rear Passenger to Cargo Section Step Up Plate For Passenger Side
1969-72*Blazer / Jimmy Rocker Box Reinforcement Assembly Plate L&R
1969-72*Blazer / Jimmy Rear Cab Floor Support L&R
69-72 Blazer / Jimmy B-Pillar Patch ( Behind Rear Lower Door Pillar AREA On Bed Side)**L&R THESE ARE NOT REQUIRED IF USING NEW BLAZER BED SIDES AS THEY ARE A PART OF THE NEW BED SIDE
69-72 Blazer Front Lower Section Bedside L&R
Paul Jr. @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 01-03-2015, 10:51 PM   #10
Moreyel
Moreyel's Avatar
Paul Jr.
When you say 'later this year', do you mean after next summer? I'd like to do mine then. How will I know when you have them available?
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2020 Ram 2500, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more.
Wife: 06 GMC Duramax 3500 4WD Single Wheel
Next: Rust removal on my Blazer.
Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup.
Members Met: Aldtime, DeadheadNM
Moreyel is offline   Reply With Quote
Old 01-22-2015, 02:30 PM   #11
Mr Banshee
Any new updates when the complete Blazer Cab Floor will be available?
Mr Banshee is offline   Reply With Quote
Old 03-25-2015, 06:39 PM   #12
da-burb
"Ochre Ogre"
da-burb's Avatar
The new Blazer floor is going to be out a while yet. The first round of floors were rejected. They are retooling so it will be 4+ months at the earliest if I were to guess.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 05-27-2015, 09:45 AM   #13
Mr Banshee
Old 01-27-2019, 01:46 AM   #14
68ls1
68ls1's Avatar
Raising this one from the ages, has a full cab floor for Blazer been ever released? Or is it still modifying the pick up one?
68ls1 is offline   Reply With Quote
Old 01-27-2019, 09:59 AM   #15
bluek5
bluek5's Avatar
Here you go.
http://www.classicheartbeat.com/cata...20Assembly.htm
bluek5 is offline   Reply With Quote
Old 01-27-2019, 07:09 PM   #16
68ls1
68ls1's Avatar
Originally Posted by bluek5 View Post
Here you go.
thanks
Old 01-28-2019, 08:34 AM   #17
twp1
Has anyone used their floor pan yet?
twp1 is offline   Reply With Quote
Old 01-28-2019, 09:15 AM   #18
Jeff1971
I had been told recently that the Blazer floor was on the menu but you couldn’t order one. That was from Classic Heartbeat about two weeks ago. He said that they were still hoping to get them but it didn’t look good.
Sounds like a modified truck floor is still the only option.
Jeff
Jeff1971 is offline   Reply With Quote
Old 01-28-2019, 02:05 PM   #19
lks dcvn
lks dcvn's Avatar
For my build - we used a standard 2wd cab floor with bracing and then measured/cut and bent the rear lip upward to match the OEM Blazer floor style.
It's doable w/ the cab floor part.
If there was a blazer floor ready to go - that would save you some time/hassle.
lks dcvn is offline   Reply With Quote
Old 01-28-2019, 08:24 PM   #20
Mr Banshee
For my build I used a 4x4 truck floor pan and modilfied it. Its some work but doable. I'm working on all the seat and cross bracing now. Here's a link to my build with pictures of it.
http://67-72chevytrucks.com/vboard/s...light=blazilla
Old 03-24-2019, 12:54 PM   #21
bluek5
bluek5's Avatar
Looks like these may have made it into production. Check out post 35 on in this thread http://67-72chevytrucks.com/vboard/s...=773606&page=2
Old 03-24-2019, 07:44 PM   #22
litebulblsc
litebulblsc's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=783537
litebulblsc is offline   Reply With Quote
Old 04-29-2019, 08:03 AM   #23
Aframe187
I just bought a cab floor at spring Carlisle swap meet from CPI Truck parts. Along with bed floor and bedsides. Woodall.. Can't wait to get installed
Aframe187 is offline   Reply With Quote
