Old member
What kind of head lights are you running and why. I have been giving mine some thought lately and was wondering what everyone else has and does to keep them in good working order. I read all this stuff about H-4, LED and I'm Hid's. Ive been thinking about buying some projection headlights but haven't found anything I think better than what I have.
I just aimed mine the other week after one of my adjusters feel out. I almost bought a set of aimer's off Ebay but decided not to. I aimed them by sight and a wall. I run these and well I'm pleased with them I would like to know if there is something else I could use that is better. I have my own relay wiring installed per the Mad electric website. If you haven't upgraded your truck's lights to the relays you really should. It's not that hard and it's not that expensive to do it. It's day and night difference. ![]() The picture of the bulbs are the ones I run on the right. the other one is one I took out of my daughters old Eclipse and swaped out to the same thing I run. Here is a couple of pictures of mine. ![]() My truck is a driver and when I say this I mean a driver. I have been on the last 2 HRPT and put over 7000 miles on my truck in a little over 2 weeks + what I drive it the rest of the year. So having good lights is a must for me. I work swing shift also so I drive to and from work a lot in the dark. So lets see what you have and what your planning on doing for head lights. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: What you got?
I have H4s, but I've never driven in the dark to see how good the work....
1970 C10 Short Stepper with 71/72 front clip. |
![]() Join Date: Aug 2007
Re: What you got?
Tri-bar blue dot headlights from JEGS.
Scotts72C10 |
Re: What you got?
I'm not sure of the manufacturer offhand, but they are hid and have a led "halo" I have em on the 67 Camaro also. Pm if you want a pic, can send a pic through fb or kik. Can't upload to the board from phone :/
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
Re: What you got?
I run halogens. I like them because they are a huge improvement over Power Beams, yet look the same and I can see just fine. I rarely ever use hi-beams as it is.
Old member
Does anyone have any projection headlights that they are using, if so how do you like them?
Re: What you got?
I have the Hella H4 conversion lights in my '69 short and at least 3 jeeps. This is a great update giving you the ability to replace bulbs and the flat glass lens is excellent. Will be putting the 135mm in my Jimmy soon. They are not DOT but I can live with that.
#8 | |
Old member
![]() Quote:
I found these on E Bay. $334.00 ![]()
![]() Join Date: Nov 2007
Re: What you got?
http://67-72chevytrucks.com/vboard/s...ight=headlight
Someone had some night time pictures running them on here |
#10 | |
Old member
![]() Quote:
