![]() Join Date: Jun 2011
question about rear end on a 65 c10
so a couple days ago i blew up my rear end on my 1965 c10 it has 3:73 gears. and the same day my hot water heater started leaking. bad day to say the least. does anybody here know from what year to year rear end will fit my truck. i have coil over springs.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 12-19-2014 at 08:34 PM. Reason: add |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: question about rear end on a 65 c10
edit....
I misspoke
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
I think '65 to early '70 is what you're after. '63-'64 used a different panhard bar mount, later '70 was slightly wider, and '71-'72 are 5 lug (and the slightly wider width that they went to in late '70).
All IIRC/AFAIK, of course. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
This is correct.......
#5 | |
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ Last edited by corvettejim1968; 01-02-2015 at 08:26 AM. Reason: add |
If you can't easily find one you might want to talk to AZ differential specialists, on Grand ave between McDowell and Thomas. I haven't personally used them but a guy I know did and was happy with them. They are almost across the road from where I work and they do lots of nice hot rods, etc.
thanks i did give them a call. they dont have anything that old. but Dino63 hooked me up with a guy so i got one for $175
thank you
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
