Old 12-20-2014, 08:24 AM   #1
hotrodelrod
hotrodelrod's Avatar
frame rivets
what is the best way to remove spring hangers and original hardware from frame? I ground down a rivet but not sure that is the way to go.
hotrodelrod is offline   Reply With Quote
Old 12-20-2014, 09:00 AM   #2
Advanced Design
Advanced Design's Avatar
Re: frame rivets
Yes, you can grind them down then using a punch and bfh drive them out of the frame. Drill through the center of the rivet if necessary to help relieve stress or tension of the rivet to the frame.
Advanced Design is offline   Reply With Quote
Old 12-20-2014, 09:08 AM   #3
hotrodelrod
Re: frame rivets
Thanks for the help!
Old 12-21-2014, 01:07 PM   #4
Iceburgh
Iceburgh's Avatar
Re: frame rivets
air chisel and heat works well after grinding
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 12-21-2014, 08:50 PM   #5
J48chevy
J48chevy's Avatar
Re: frame rivets
It also helps if you have a friend with a plasma cutter. Cut them rivets like butter for me. Haha
I did the grinding for a few but did not like all the dust but it does work
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end.
http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670
J48chevy is offline   Reply With Quote
Old 12-21-2014, 08:55 PM   #6
slowcpe
slowcpe's Avatar
Re: frame rivets
I've been grinding them down as I have a less than stellar air chisel. As long as you are not in a hurry, it's not bad. I have a 40-grit and 80-grit wheel. The 40 will chew through the head in a hurry but makes me nervous around the frame. I then use a punch and hammer to get the rest out. For some stubborn rivets I'll drill them out.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
