Engine rebuild or replace???
Greetings,
I have a 69 C-10, it is an all original no rust truck. The 307 runs ok, but it has a knock when cold and is using about a quart every 500 to 750 miles. The compression is 175# on all cylinders. I'd lean toward staying original, pulling the engine and rebuilding it, but to do it right I'd probably have as much $ in it as I would if I bought a new 350. I am going to be driving it and may be driving it in higher altitudes. My questions are. The Chevrolet 290hp 350 new crate motor comes ready for a 4 bbl carb, can those be equipped with throttle body EFI? If I rebuild my engine can it be converted to EFI? I hope some of you can tell me some ins and outs from your past experiences. Thanks for all replies, Phil |
Re: Engine rebuild or replace???
I was in your place last year with my worn out 350, I had it rebuilt and now looking back I wish I would have just gotten a new engine from jets or summit ect. I payed $800 and all that got me was bearings and a hone. With these trucks the vin is not stamped to the engine. I say pull the 307 put it in a corner or use it as a core.
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town" |
If it were mine I'd rebuild it myself, which I'm capable of doing. Machine shops will cost you. A lot of guys bought crate engines on here for about $1200.00s, some had problems with them, some didn't. I'm sure they will chime in soon. If you're looking for more power, Get the 350. Good luck...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
I don't see a rebuild costing less than $2500, because I'd have the crank ground and balanced, new cam, bored, new pistons, lifters, rockers, ect, and I'd have my machinist buddy build the heads for unleaded fuel. Other than the machine work I'd build the engine. A new Chevrolet crate engine is $3200 without a carb or distributor. I'd really like to install a throttle body fuel injection, mainly for the carburetor look. Thanks for the replies.
One would think that you would see a big difference in the torque (less) and the fuel mileage (less) if you change to the 350.
Personally I would rebuild the 307, but I am a bit partial to them.
Terry Soon to be retired and moving to Bristol, TN. |
The only reason to rebuild the 307 would be to keep the truck 100% original, a crate 350 or bigger is the way to go IMO.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
rebuild projects are a bad bet as 50% or more have catastrophic failure within 500miles with no warrenty to save you gm factory crate engines are about 95% or more success rate with no real problems and it is covered by an excellent warrenty program for a long term
![]() Join Date: Nov 2013
Keep the original engine so that is not is part of the keep original or not equation
307's don't have the reputation of a 350, but I had one and no problems the crate engines have been known to have problems, but have a warranty. You can get one from jegs on sale shipped to you for 1500 bucks-can't go wrong, so for 1500 you have two engines, instead of one if you rebuilt it |
350 crate motor....$1500 or less at times with free shipping from Jegs...a no brainer.
Moderator
![]() Join Date: May 2007
350 crate motor from Jegs and be done with it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#11 | |
Who ever has been building those engines should be fired.
![]() Join Date: Aug 2014
#13 |
Everyone is talking crate engines from Jegs at $1500, sounds great, still a rebuilt engine by who knows who??? I've built British car engines and British motorcycle engines for a while now, and other than a defective head gasket I installed on a 69 Triumph Daytona I've had great luck, I think the machine work is the key. We are talking apples and oranges here. I'm comparing a proper rebuild, by me, to a "new" GM 350, at least I think this is new:
http://www.chevrolet.com/performance...50-290-hp.html I'm wondering if I can install throttle body fuel injection on the Chevrolet built engine, or on the rebuilt 307 I do myself???? |
#14 |
I say sure, why not. Carb's, TBI's or straight up fuel injection just mixes up the air and fuel then sends it to the cylinders.
TBI's and FI's are just computer controlled and "should" get you a bit better fuel mileage. I do believe though, if you install a TBI or FI, you will need to run a fuel return line back to your fuel tank and possibly change the fuel pump to one with a higher volume.
#15 |
Thanks Tcrist. I'm thinking about installing a rear tank and get the one out of the cab, but the cab tank is new, so I don't know.
#16 |
I was thinking about installing a rear tank in mine but am unsure of where to put the fuel filler. I don't care for them in the bed floor but am unsure where to put them in a step side without looking gaudy.
Guess a rear fill under the license plate would do but I have had issues with that location in my 68 Chevelle leaking fuel. Maybe a racing fuel filler type set up would be best.
#17 | |
http://www.hotrod.com/how-to/engine/...iant-efi-test/ The only difference between a GM 350-260HP and a GM 350-290HP is the cam. The compression is too low on that engine for the cam they put in it and you may be disappointed with the low end power and gas mileage. That's like $450.00 just for the different cam, and it's not the right cam. So, just get the 260 and slip a cam in it if you want, something more appropriate for that engine. http://www.jegs.com/i/Chevrolet-Perf...06#moreDetails Let me know if you are interested I can recommend a cam based on your application (vehicle weight, rear end gear, towing or not, etc.). |
#18 |
![]() Join Date: May 2013
Id go for the 350 create allso , you have a much better chance off it leaking "less" ,,, and more torque ,, what a truck wants and needs
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#19 |
dump the 307 and replace it with a 350 with a good alum intake and carb
#20 |
#21 |
Mechanicalman, Thanks for the links, it seems to be about the same as what is listed on Chevrolet.com and at $1500 it may be my best solution. I may do some towing, perhaps a light car like an MGB, don't think that will require anything special.
67chevelle, my British car rebuilds don't leak. The motorcycles are a different story, they will leak a little gear oil. |
#22 |
if you do decide on a crate 350 take all the info you get on them and go into your local gm dealership and see if they will match the mailorder price the dealer here will and I like buying local on princxeple
#23 |
Moderator
![]() Join Date: Jun 2008
I agree, a crate motor is the way to go. If YOU rebuild your engine, you have not warranty. If you buy a crate motor, you have coverage for some time.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#24 | |
#25 | |
1971 350 R2carb 8.5 compression 245HP @ 4800rpm 350 ft lbs @ 2800 rpm 1971 350 R4carb 8.5 compression 270HP @ 4800 360 ft lbs @ 3200 My opinion: MAYBE slightly less MPG with the 350 (only at low load conditions), but at least 50 MORE ft lbs torque with the 350. |
