Old 08-20-2003, 12:27 AM   #1
white68chevy
what does it take to make a 383 stroker?
I have been wanting to start a bulid on a 383 stroker. I have never done one before and i was wondering what all it took. Like bore and crank and pistons and rods and such.
1968 swb
IM-Bufechevy56
If its to loud then your to old
white68chevy is offline   Reply With Quote
Old 08-20-2003, 12:34 AM   #2
Nova_Cobra64
Nova_Cobra64's Avatar
As far as my knowledge goes, a 383 is a 350 block bored 30 over with a 3.75 crank out of a 400. I think either the block or the crank needs to be ground down in a few spots due to clearance issues. I think the crank journals need to be taken down too., not positive tho.
There are kits now too.......I don't know what block work has to be done when you buy those.
Somebody should be able to help more than I have.
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
Old 08-20-2003, 12:41 AM   #3
cnshoot
cnshoot's Avatar
350ci bored .030 over 400 crank long rods
72 cst 2wd blazer sb soon to have tilt manual
72 gmc swb fleet 2wd bb air tilt auto
93 c/3500 crew-cab dually
03 chevy suburban LT quadrasteer c/2500 4x4
cnshoot is offline   Reply With Quote
Old 08-20-2003, 12:43 AM   #4
cnshoot
cnshoot's Avatar
or you can de-stoke a 400 to a 383 buy puting a 350 crank in it
Old 08-20-2003, 12:43 AM   #5
ABHaulR
ABHaulR's Avatar
yes the crank has to be turned down to fit the 350 main bearing size. you can get a crank from any aftermarket supplier that is a direct drop in.
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 08-20-2003, 12:46 AM   #6
white68chevy
man yall are quick! thanks for the info. the whole clearence thing was my biggest corncern. Anybody else?
1968 swb
IM-Bufechevy56
Old 08-20-2003, 12:54 AM   #7
leadfoot067
horsepower junkie
youll have to clearance a few of the rods...pending what rods you use...400 rod is 5.65" or 350 rod is 5.7"...the longer rod is generally prefered..400 rods arent known for their strength also the bigger cam you run the more u gotta take off the few rods...some clearancing has to be done at the bottom of each cylinder for the rods but its nothing major...hope this helps
leadfoot067 is offline   Reply With Quote
Old 08-20-2003, 01:00 AM   #8
Hooter
My other Love
Hooter's Avatar
about 4500 hundred bucks
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 08-20-2003, 01:21 AM   #9
Blue4x4
Blue4x4's Avatar
I had my 383 stroker built for $ 2200.00 . It included: chrome valve covers, intake manifold, oil pan and chrome timing cover. I will post the pic tomarrow.
Blue4x4 is offline   Reply With Quote
Old 08-20-2003, 01:34 AM   #10
tripp
Blue4X4, give us the scoop! i'm looking to put a new engine in my '92 ext. cab and why get a crate motor from GM for $1300 if you can get a stroker for $2200? i look forward to your reply. thanks.
68 SWB Stepside
72 Cheyenne 20
72 SWB Fleetside
72 Suburban
72 2wd Blazer
tripp is offline   Reply With Quote
Old 08-20-2003, 01:35 AM   #11
cnshoot
cnshoot's Avatar
try performance automotive warehouse buy the cat. its worth it if you are building anything
Old 08-20-2003, 08:54 AM   #12
Randy70C-10
Randy70C-10's Avatar
Horsepower versus GM warranty, it's a tough decision. I'm hard-headed so I always go for the horses.
Randy70C-10 is offline   Reply With Quote
