![]() Join Date: Nov 2010
Anyone know where to get one of these?
I am in need of a new wiring harness that goes from the firewall to my starter. It's located up by the heater just to the right of it and runs down to the starter with one blue wire running to the sending unit by the distributor. It's been spliced and taped up it won't work anymore. I can make one I guess but just looking for a new harness if they are available but I can't find them.
Re: Anyone know where to get one of these?
Funny, I got 667000 hits when I searched...
![]() The 1st 2 links will have direct replacements but you can do better on price by buying the same harness elsewhere. Brother's is a board vendor. wiringharness.com http://americanautowire.com/ ebay.com https://www.google.com/search?q=65+c...ess&gws_rd=ssl brotherstrucks.com |
I just cut mine out! The only wire that was in use was the purple wire to starter. The Battery main wire and that wire are the only ones I have. I ran a red wire to the coil. New electric gauges I put in, The Water Temp got a Blue Wire, The Oil got a Green wire. That's all that would be in that harness minus gauge cluster pink wire.
If you don't have a Yellow 60-66 Manual I would get one. The wire diagrams are very useful let alone all the info you can shake a stick at. ![]()
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 12-20-2014 at 07:38 PM. |
Yea they show a lot of engine harnesses but it's not what I'm looking for I don't think..just the wires from the solenoid to the forewall unless im missing it
![]() Join Date: Aug 2008
I'm not getting how I am the only one not finding a truck starter harness.
Most places call it an engine harness.
In addition to the purple starter wire, this harness typically includes a resistance wire to power the ignition coil, a green wire or two for the temperature gauge or hot/cold lights, a blue wire for the oil pressure light, and one of the ammeter wires (on trucks w/factory gauge clusters). |
I believe what you need is the Engine Harness. Goes to the starter, HEI and Temp Sending Unit. M&H has them if you go to their website that I posted. You will need to specify whether you have warning lights or gauges on your cluster.
#9 | |
Engine wire harness is what they call it. This one is standard Brothers Trucks has a HEI one as well.
http://www.brotherstrucks.com/prodin...number=EH03380
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Found some, i appreciate the help. I was also thinking about making one myself as well and I have an hei. Shouldnt be too hard to fab one up. but if not i can probably just pick one up..Id just like to learn a little more about electrical stuff.
