Old 12-20-2014, 07:09 PM   #1
sgr60
Switched Ignition wire
I need a switched ignition source up by the drivers side firewall in the engine compartment. I'm looking at the wiring diagrams now, but if anyone has a source they typically use and can let me know, that would be great.
Thanks!
'84 K20 350/465/208
sgr60 is offline   Reply With Quote
Old 12-20-2014, 07:11 PM   #2
sgr60
Re: Switched Ignition wire
Maybe the pink wire feeding the distributor?
'84 K20 350/465/208
Old 12-07-2015, 03:58 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
I need a key-on switched power feed in my engine bay as well. Any updates? Suggestions.... PICTURES?
Rich
1972 K5 Blazer CST Click HERE
Old 12-07-2015, 08:33 AM   #4
chrismoore701
chrismoore701's Avatar
I have a painless harness installed, so I had some open wires I could use. I used the power wire to my fuel pump. Just check your fuse block and see what powers up on key
http://67-72chevytrucks.com/vboard/s...d.php?t=685572
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 12-29-2015, 06:05 PM   #5
68Timber
I know the pieces fit
68Timber's Avatar
Originally Posted by Chaplain View Post
I have fresh knowledge of this issue as I am currently cleaning up my fuse block and repening my gauge cluster. Not sure what year your truck is or whether or not you're using an aftermarket wiring harness but in my 79 there are three IGN spots on the left sided of my fuse block. These are triggered by the ignition.
Hope that helps.
I was searching for a good source of switched hot for some aftermarket gauges I'm installing and found this thread, my 85 has the same three IGN spots on the left side. I'd like to connect here and run an inline blade fuse but what's the ideal way to connect? I'm guessing I need to take it off the firewall and connect to the backside?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-29-2015, 06:20 PM   #6
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=230536
powerdriver 1958 is offline   Reply With Quote
Old 12-29-2015, 06:57 PM   #7
68Timber
68Timber's Avatar
I have those, just curious about the proper way to make a permanent connection. I can put a male terminal on the end of the wire and push it into the clip in one of the IGN spots, but that seems hokey.
John
74 Honda Z50 build
Old 12-29-2015, 07:08 PM   #8
ray_mcavoy
This is the type of connector GM used to factory wire accessories that plug into the "IGN" receptacles on the 78+ fuse boxes.
They plug in to the front of the fuse box. And unlike a generic male blade terminal, the connector's plastic shell has a latch to hold it securely in place.
Here's one source for them --> http://www.repairconnector.com/gm-ig...ock-tap-clear/
ray_mcavoy is offline   Reply With Quote
Old 12-29-2015, 07:16 PM   #9
rich weyand
rich weyand's Avatar
I just use generic female blade terminals. Done.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 12-29-2015, 07:22 PM   #10
68Timber
68Timber's Avatar
Thank you sir, that was exactly what I needed to know. I ordered a small handful of them.
John
74 Honda Z50 build
Old 12-29-2015, 07:36 PM   #11
ray_mcavoy
You're welcome!
I should probably mention that those connectors are keyed so they will only plug into the "IGN" receptacles. If you need to plug into other receptacles on the fuse box, there are similar looking connectors specifically keyed for them as well. For example, here's the one that plugs into the "BAT" receptacle for constant power --> http://www.repairconnector.com/gm-fu...wer-always-on/
Old 12-29-2015, 08:17 PM   #12
68Timber
68Timber's Avatar
You're welcome!
Would the BAT receptacle be good for running power to, say, four USB charging terminals? Or would you go straight to the battery? I think most cell phone chargers are around .5 amps, so I'm thinking it'd be OK to run them on one circuit.
John
74 Honda Z50 build
Old 12-29-2015, 08:46 PM   #13
ray_mcavoy
Yes, that should be okay to hook up to the BAT receptacle.
The BAT receptacles are protected by the 20A "HORN / DOME" fuse. I believe many years have the cigarette lighter wired to this circuit as well. And the optional clock or digital stereo (if equipped) is also plugged into the BAT receptacle. So just keep in mind these other loads that may already be on this circuit when you consider adding more.
Old 12-30-2015, 12:46 AM   #14
68Timber
68Timber's Avatar
That is good news. This is on my CUCV, so it doesn't have a dome light. At least not yet, it needs one. On the horn circuit I added the four Caddy ACDF horns but added a relay next to them when I did. So I should be good adding a few chargers there.
Bro. Ray to the rescue.
No doubt!
John
74 Honda Z50 build
Old 12-30-2015, 12:59 AM   #15
mcmlxix
mcmlxix's Avatar
I see all the info is pointing to sources in the cab of the truck. But is there any switched power already in the engine bay besides the HEI?
Rich
Old 12-30-2015, 02:28 AM   #16
rich weyand
The YEL/BLK wires on the wiper motor and washer solenoid should be hot with the ignition.
Rich Weyand
1978 K10 RCSB DD.
Old 12-30-2015, 09:13 AM   #17
gmachinz
At the firewall bulkhead you can also tap into your (for 1981-up anyway) pink w/blk stripe 14ga wire. This is the switched 12V source to one side of your oil pressure switch for the electric choke.
gmachinz is offline   Reply With Quote
Old 12-31-2015, 08:35 PM   #18
48cj2a
48cj2a's Avatar
John,
Carefull what you tap in the CUCV and use a meter, not a test light. There are 24v sources in the CUCV fuse block. I'll send you a good CUCV Fuse Block Aid that explains what is controlled by the Ign, B/O and Service Lamp Switchs,
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
