12-20-2014, 08:37 PM | #1 |
rearend id help
rearend is in my 57
its a 12 bolt and has a eyelet on top of rearend for a panhard bar and is 6 lug wondering what year rearend i may have wanting to change to 5 lug but wanna order correct parts any advise is apreciated looking at axles at summitracing YA G3893606 Last edited by wick22; 12-20-2014 at 09:04 PM. |
12-20-2014, 09:12 PM | #2 |
Re: rearend id help
Pictures might help. If it's a stock axle, 12 bolt cover and six lug axles is probably a truck 12 bolt. It's not as strong as a car 12 bolt but it's usable for many applications. Does this axle look like yours?
The Yukon axles might work. Double check length before ordering. |
12-20-2014, 09:23 PM | #3 |
Re: rearend id help
I just narrowed my GM 12 bolt rear end, dealt with Moser Axles - they were quick, and even better - they fit the first time !
You can get a work sheet off their website, call them with the measurements you want. I found them really easy to deal with. |
12-20-2014, 10:21 PM | #4 |
Re: rearend id help
12-bolt, but no eyelet. What do you'all think I have?
There are numbers on the top passenger side axle, but I can't read them very well.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck Last edited by Highsider; 12-20-2014 at 11:51 PM. |
12-21-2014, 12:34 PM | #5 |
Re: rearend id help
12 bolt truck. Rear cover is unique to that rear. Need numbers to try and narrow it down.
12-21-2014, 12:44 PM | #6 |
Re: rearend id help
there are numbers on it ill get them
id def like to id specific year and specs on it i do know its a 3.73 open diff |
12-21-2014, 01:10 PM | #7 |
Re: rearend id help
looks like the same 12 bolt rear i have in my truck from a 1972 chevy truck
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
12-21-2014, 01:30 PM | #8 |
Re: rearend id help
Tell me what that "panhead" bar does?
I was thinking mine was stock for the original 6-cylinder it came with and had a 3.73 ratio. I have 5-bolt, but I wondered if that has been updated. I can't recall how many lugs my 1955.2 I owned when I was 16.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
12-21-2014, 04:10 PM | #9 |
Re: rearend id help
The 67-72 Chevy truck had rear coils. The panhard bar keeps the truck located properly. That was done so the Nascar boys could run a three link coil sprung rear end. They still use it today. GMC got coils in '67 too but they had a bad tendency to wheel hop in mud and loose dirt so GMC switched back to leaves in '68 or '69.
12-21-2014, 05:57 PM | #10 |
Re: rearend id help
Want to add to the above:
First year for coils was '60, not '67. Article and pictures here: http://www.earlyclassic.com/Tech.asp...;s+Makeover+II |
