PROJECT 7DEUCE
![]() Join Date: Dec 2002
hinge pocket's
I was looking a door's to cut up for my blazer and some door's seem to have a recessed hinge pocket and some do not, why is that?? Also when I cut the door's do I need to transfer the big latch plate that bolt's the the door in the jamb?? And one last ? should the passenger side also have the big hinge plate set-up?
Thank's Luke
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
You will want to install the latch reenforcement on your Blazer door, otherwise you will have the possibility of the cracks in the latch area.
I am not sure what "big hinge plates" are. Jim |
PROJECT 7DEUCE
The big hinge plate would be the unboltable ,is that a word piece that bolt's the door where the latch is?
I believe that you are refering to the heavy backing plate that the striker bolts screw into. If this is the case, yes it should be on both sides.
Jim |
PROJECT 7DEUCE
That would be what I am refering to thank's for the help.
