pedal bolts?
So I snapped the little screw on which the gas pedal attaches, anybody have any ideas? I couldnt find any reproductions unless im not looking in the right place. I thought about welding it. What ave others done?
Junior Member
![]() Join Date: Mar 2005
Re: pedal bolts?
Had two break off. Got an aftermarket pair from a vendor. Drilled oversized holes through the broken pieces. installed new studs with nuts on the bottom side of the floor panel. The replacements were long enough and it worked like a champ. No welding required!
Re: pedal bolts?
Do you know whay they are actually called?
![]() Join Date: Mar 2004
Re: pedal bolts?
Is it a threaded ball stud? Like you would use on a gas shock for a newer style hood or hatch?
http://m.napaonline.com/tablet//part...608_0361162040
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
Junior Member
Re: pedal bolts?
LMC catalog page 51 item # 4- Accelerator pedal stud
