Old 12-22-2014, 12:05 AM   #1
TBONE1964
Cluster King
TBONE1964's Avatar
Gauging interest on "volt gauge conversion kits for 67-72 gauge clusters.
It has recently come to my attention that some of you using AAW wiring kits have been told that they will not support the use of the factory amp gauge. I have edited the statement that there is a risk of fire when using a stock amp gauge with a newer high amp alternator. I cannot confirm or deny the claim. If it is a concern, then you should do further research.
With that said, I am thinking about creating a volt gauge conversion kit that would come with instructions for installation and should be a 15-20 minute job for most.
I would supply everything needed for installation in a stock cluster. The needle and gauge face can appear to be stock for those concerned about looks.
Let me know who may be interested in a kit and I will make a decision on whether to move forward.
I will be posting photos of a conversion in a few days for all to see.
Thank you for your time and consideration,
Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 12-22-2014, 12:11 AM   #2
michael bustamante
michael bustamante's Avatar
Re: Gauging interest on "volt gauge conversion kits for 67-72 gauge clusters.
Using an afternarket volt guage that looks similar to and will fit in the stock ammeter location?
1967custom
michael bustamante is offline   Reply With Quote
Old 12-22-2014, 12:12 AM   #3
kamikazekyle05
kamikazekyle05's Avatar
I'm using the AAW kit, I would be interested
kamikazekyle05 is offline   Reply With Quote
Old 12-22-2014, 12:20 AM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Actually Michael, the volt gauge will be a factory style 1976 and up Chevy truck gauge converted to fit in the factory location of the amp gauge.
This was not my idea entirely but I thought there would be a market for a kit with instructions.
Old 12-22-2014, 12:22 AM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
I will be posting some photos soon, so you can see what the conversion looks like as well as what you would get with the kit.
If there is enough interest, I will be posting kits for sale on the parts board.
Thank you for the interest,
Tom
Old 12-22-2014, 12:33 AM   #6
Lattimer
Lattimer's Avatar
Interested.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 12-22-2014, 01:07 AM   #7
jmader
jmader's Avatar
I would be interested in one of these. What are you thinking for a price?
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 12-22-2014, 01:07 AM   #8
67ctener
67ctener's Avatar
I'm un aware of this issue but plan to use an aaw kit. If this is the case I would be interested in the conversion? So the stock ammeter gauge will not work?
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 12-22-2014, 01:24 AM   #9
TBONE1964
Cluster King
TBONE1964's Avatar
It has been brought to my attention that if you are using the AAW wiring kit for custom applications, they recommend not using an amp gauge.
Also if you are using a 100 + amp alternator, the factory amp gauge and wiring will not support the extra amp output from the alternator.
If you are using the "factory fit" AAW kit with a stock alternator, then you will be OK with the factory amp gauge.
Hope this helps,
Tom
Old 12-22-2014, 01:26 AM   #10
TBONE1964
Cluster King
TBONE1964's Avatar
Hey Jeremy,
I have not got a price together yet. i am still working out some details. I will be posted a thread on the parts board soon with pricing.
Stay tuned...
Take care,
Tom
Old 12-22-2014, 02:10 AM   #11
57taskforce
All about them K’s
57taskforce's Avatar
I'm interested as well. I plan to use the aaw kit and have read the conversion threads on here. It would sure be convenient to get all the parts in one swipe.
Tyler
57taskforce is offline   Reply With Quote
Old 12-22-2014, 08:34 AM   #12
randy.powell
T-Bone - sign me up!
B/R,
RP
randy.powell is offline   Reply With Quote
Old 12-22-2014, 09:08 AM   #13
engineer_gregh
engineer_gregh's Avatar
I would be interested.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 12-22-2014, 09:14 AM   #14
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Interested
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 12-22-2014, 09:41 AM   #15
Kennuck
Kennuck's Avatar
Here is the Warning from the AAW 510089 Classic Update Kit.
"This kit WILL NOT support the use of a factory ammeter. All AAW kits are engineered to supply the optimum charge to the battery. To achieve this performance, we route our 8ga. charge wire directly from the alternator output charge terminal to the starter battery terminal. Due to the path of the charge being altered from the
stock configuration, the gauge can no longer see a charge vs. a discharge, so it will not work properly. When ammeters were originally used, most generator or
alternator current outputs were rated at a maximum of about 25-60 amps. Modified cars being built today typically utilize a 100 amp or higher output alternator.
With these higher current units, ammeters, generally speaking, become a safety hazard. Ammeters are usually wired in parallel to the charging circuit, are
typically unfused, and can short very easily causing a fire. A voltmeter is recommended as a good alternative."
Tom is building me a cluster for my LS swap so I asked him if he could include the volt gauge. I guess I'm the test mule
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 12-22-2014, 09:52 AM   #16
Lee H
Lee H's Avatar
Tom, I'm running a AAW classic upgrade kit. I'll take one of you conversion kits. Will it include a harness? Looking forward to the for sale thread. Thanks for doing this, Lee.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-22-2014, 10:01 AM   #17
Mike C
Mike C's Avatar
This would be nice for people who didn't want to run an ammeter.
I'm pretty sure the stock ammeter is wired using a shunt. Unlike a regular installation of an ammeter, not all of the vehicle current runs through the meter. It may not be incorporated in the harness, but you could add it. Here's a quicky video on youtube that explains it. Also Google "wiring alternator with shunt"
https://www.youtube.com/watch?v=7MGed7WKwAA
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-22-2014, 10:55 AM   #18
Matt Cramer
I'll take one if the price is right. My LS swap has the alternator run straight to the battery and no easy way to put an ammeter on it.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 12-22-2014, 11:00 AM   #19
67 chevelle
67 chevelle's Avatar
very interested , add me to the list
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 12-22-2014, 11:43 AM   #20
TBONE1964
Cluster King
TBONE1964's Avatar
Thank you everyone.
I have you all on my list. Stay tuned for a thread on the parts board that will explain options and everything included in the kit. I am guessing after the holidays for a thread launch.
I really appreciate the interest. Hope all of you have a Merry Christmas and Happy New Year,
Take care,
Tom
Old 12-22-2014, 12:22 PM   #21
Wizo
Wizo's Avatar
Interested
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 12-22-2014, 01:59 PM   #22
elf w/capital T
Very interested in a stock looking and fitment gauge!
elf w/capital T is offline   Reply With Quote
Old 12-22-2014, 04:13 PM   #23
WiggyHD
I'm interested. I have the AAW harness on my wish list...
Mark
Retired Air Force/Disabled Vet
1969 Chevy C-10, On the way to greatness!
WiggyHD is offline   Reply With Quote
Old 12-22-2014, 04:20 PM   #24
BrianG
BrianG's Avatar
Add me to the list of those who are interested.
BrianG is offline   Reply With Quote
Old 12-22-2014, 04:51 PM   #25
franken
The factory battery gauge carries no current and is fed by 2 sources of 12V.
There's no danger of fire regardless of the rated current of the alternator.
AAW may not support using the original gauge, but it has nothing to do with fire or the alternator.
franken is offline   Reply With Quote
