Old 12-22-2014, 12:22 PM   #1
bbcmudtruck
Looking for ideas on brakes/boosters/masters
I want to shave my firewall this winter and I'm looking for ideas on what you guys did with the big old bulky brake booster and master cylinder. I have a 73+ complete brake system. The prop valve is located down on the front cross member, just like it would be on the square body trucks. What I would like to see are ideas and solutions to having a cleaner firewall. IE smaller boosters, relocated boosters/masters etc. I would also like to get some ideas on how to plumb the brakes in order to keep as much is hidden as possible. Thanks!
bbcmudtruck is offline   Reply With Quote
Old 12-22-2014, 12:30 PM   #2
no1udknow
no1udknow's Avatar
Re: Looking for ideas on brakes/boosters/masters
I used a 85 booster and master cyl, it sits pretty high, might clear fenders. At first I was worried it wouldn't clear the hood. The other option is a hydro boost, I have seen lots of guys do that, and then tuck the booster under the truck up in the frame.
Built not bought!
My dad always tried to convince me HEI was pointless!
Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding
My build : 68 C10 Short Bed Conversion
no1udknow is offline   Reply With Quote
Old 12-22-2014, 08:16 PM   #3
dirtyjim
dirtyjim's Avatar
I'm running a late model astro van booster flush mounted, I would guess its around 9" and a mid 80's aluminum c10 master cylinder. right now my brake lines are stock from a 85 c10 and my prop valve is mounted on the front frame crossmember. when I replace my body mounts I'm going to pull the front clip and run new ss brake lines, they will come straight back from the master cyl. then down the firewall and run inside the frame to the prop valve. I think that would be about as clean as you could get them without running a under floor street rod style master cyl mount.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 12-22-2014, 08:26 PM   #4
Fitz
Short of going to a booster and master that mounts under the floor, your only alternative is a dual diaphragm booster in the stock location. 7 in in diameter.
Fitz is offline   Reply With Quote
Old 12-22-2014, 08:32 PM   #5
bs46488
Hydro boost.
bs46488 is offline   Reply With Quote
Old 12-22-2014, 10:12 PM   #6
mooseknuckles
mooseknuckles's Avatar
wildwood master cylinder, manual brakes...
mooseknuckles is offline   Reply With Quote
Old 12-22-2014, 11:30 PM   #7
bbcmudtruck
What exactly would that consist of? Thanks!
Old 12-23-2014, 12:13 AM   #8
SierraMtns
SierraMtns's Avatar
It would be this. Nice clean set up.
http://67-72chevytrucks.com/vboard/s...d.php?t=650420
SierraMtns is offline   Reply With Quote
Old 12-23-2014, 12:56 AM   #9
Madspeed
Guest
Posts: n/a
lol. it would consist or crappy braking. yes im aware of how to change pedal leverage but your gonna loose pedal travel in the process. hydroboost and fab it under the floor. I use hydroboost on all my junk
Old 12-23-2014, 09:35 AM   #10
bbcmudtruck
Thanks for the info hahah. That was going to be my next question. What does everyone use for hydro boost? Any part sources or pictures of installation?
Old 12-23-2014, 01:56 PM   #11
bs46488
I use hydroboost because of a low vacuum issue. I didn't want to mount a spare tank to keep the vacuum up.
A hydrobooster is also much smaller than your standard 11" power booster, so you get a lot more wiggle room in the engine bay.
I fab my systems with factory boosters/masters, but a great bolt on solution is here:
http://www.hydratechbraking.com/
Old 12-24-2014, 11:02 AM   #12
bbcmudtruck
Thank you!
Old 12-24-2014, 09:14 PM   #13
Madspeed
Guest
Posts: n/a
Oh if you go Hydro dont forget a face mask. Your first stop may net you a broken nose
Old 12-24-2014, 10:47 PM   #14
SaltyC20
SaltyC20's Avatar
Have you considered CaptainFab's booster bracket? It tucks the booster closer to the firewall and allows the use of universal boosters.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484
1968 Chevy C20
SaltyC20 is offline   Reply With Quote
Old 12-25-2014, 12:11 PM   #15
bbcmudtruck
No sure haven't. Does he have a website or somewhere I can see this setup installed?
Old 12-25-2014, 08:42 PM   #16
Madspeed
Guest
Posts: n/a
I took a 1/4 inch plate and fabbed my own hydro to firewall plate. Depending on years they used hydro boost on the factory 71 up one ton up chassis. I held one in my hands one time. It had inverted flare fittings. You can make your own hyd lines at home from stainless braided hyd line and hyd stainless an fittings. So you can do any style ends you want. I used a hydro from a dmax on my 72 blazer, umm wait I first used one front the 80s on my 454 solid roller motor that had no vac then dmax . Making the tang in the plate req me to finalize the hole with a half round file
