which CORRECT radiator?
purchased a new radiator that was supposed to be correct only to find it is not. 1977 350 heavy half ton with a th-350.
If I had the original still, Id measure it to choose the right one. The one I have now is a little oversized and from what Ive come across seems to be for the big block ? Its a little too big to sit in the brackets and "fingers" by just a bit. Any idea which radiator SHOULD be in there? Id like to get the shroud back on and the radiator mounted correctly. |
| Bookmarks |
