Build sheet bummer
After learning on this forum, that some trucks still have their build sheets under the seat, I went to look for it. My truck seems like a true survivor with a rebuilt engine. Found most of the build sheet and was able to put it back together! But it's not my VIN. Must be a swapped out bench seat. Bummer!
Re: Build sheet bummer
That isn't ideal, but cool no doubt. At least it confirms your truck may not be as original as you thought; and still, it doesn't make it any less cool.
![]() Join Date: Jan 2002
If it makes you feel better, I found a couple build sheets in a 71 that we had. 2 of them were for the truck and one was for a one ton dually. The 71 was a short box 2wd
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Mine was stuck on the front of the box behind the cab, so there's a chance that your original may still be there.
I didn't find it until I pulled the cab because I'd never heard of it being there. You can probably peek in from the top or bottom. It was stuck to wet original paint, so hard to get off. - Dave
Moderator
![]() Join Date: May 2007
You have a Fremont truck so there is a good chance there is another one somewhere in the cab. The build sheet was supposed to be thrown away at the end of the assembly line, but a lot seem to have made their way into Fremont trucks. It does not necessarily mean your seat has been swapped out. Others have also found build sheets that do not match the truck on what they thought was untouched and original.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Is your VIN a Fremont truck? If so keep looking. My Fremont build sheet was under the tar paper, under the floor mat, near prefect condition.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Look inside the cardboard gas tank cover too. Good chance one may be there
Unfortunately build sheets were never designed to be permanent, but they did contain much more detailed info than the SPID. Build sheets list selling dealership and build dates to name a few. Is anyone out there re creating build sheets with the correct type paper and font?
![]() Join Date: Sep 2007
mine had three correct ones and one that didnt belong to my truck. 2 in the seat and one taped to the gas tank. found that when i removed the cardboard cover.
1967custom |
#10 | |
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 12-31-2014 at 11:18 AM. |
![]() Join Date: Oct 2009
While it is a nice to have, it's certainly not a requirement for proving an original truck. Matching SPID VIN, Frame VIN, and GVWR tag VIN are the important ones. I had TWO build sheets under my seat, neither one was the correct one. Musta been the late shift in Fremont... Ha. Nice truck in your pics, show us more please! Always interested in CustomD's as they may be hidden Highlanders...
Carpe manana
![]() ![]() Join Date: Dec 2010
I'm told Flint built trucks are unlikely to have build sheets in the cab or elsewhere...anyone know of a K5 that's had a build sheet in the cab?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#13 | |
Build sheets were affixed to the front of the pickup box for the same reason as the front of the cab: to inform the assembly line workers what option content that box required. What might not be obvious (until one thinks about it) is that the pickup box and cab went through the paint shop together, on one body carrier, but with enough space to allow the cab back and front of the box to receive full (or almost full) paint coverage, as shown below. In the photo below the cab/box have been through the ELPO dip tank but have not yet had the color coat sprayed on. Photo credit: Jeff at 73-87.com, via GM K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#14 | |
-Jeff |
