Old 08-20-2003, 09:11 AM   #1
redone71
redone71's Avatar
Air Bag Question
Is it possible to run air bags on 20's without cutting bed and front wheel wells? If not what is the largest diameter possible with this configuration.
On the eighth day, he made trucks and saw they were good.
redone71 is offline   Reply With Quote
Old 08-20-2003, 10:53 AM   #2
nosto
Flamin' Bass
nosto's Avatar
Redone71 -
I couldn't tell you what's the largest diameter you can use without cutting, but I'm running 255/45X20s on 20X8s, front and rear. With bags dumped, I have about 1/2" clearence from the top of the tire to the fender in front and 1 1/2" in back. It is fully drivable when dumped, but only on really smooth surfaces, otherwise it tends to shake your fillings loose.
My setup is a little different: While most board members have used drop spindles, my truck already had dropped lower A-arms, about a 2 1/2" pocket (and no bumpstops), so I didn't bother changing. Also, I understand the stepsides have a 'bit' less space in the rear for wide tires; you could likely go a bit wider - 275? 285? on a fleetside.
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 08-20-2003, 11:42 AM   #3
redone71
redone71's Avatar
Thanks Nosto. Do you have a pic of ride height?
Old 08-20-2003, 11:43 AM   #4
fastbagged68
fastbagged68's Avatar
You can go low but it will sit about the height of the other truck in this post. You might want to go with 18's and a small tire- check out the 65 pickup on my website- www.dragginbycustoms.com - that truck has got a small hole in the bed so imagine the rear sitting up another 2 inches. Hope this helps.
fastbagged68 is offline   Reply With Quote
Old 08-20-2003, 12:12 PM   #5
redone71
redone71's Avatar
fastbagged I cannot see the pic just a red x in the upper left corner
Old 08-20-2003, 12:38 PM   #6
fastbagged68
Click on projects then click on carlo 65 pickup and it should come up then. I did not do the work on that truck. I sold him that kit. and he did the install.
