![]() Join Date: Jun 2014
Ram Horn Manifolds
I am looking to put on some Corvette manifolds but not sure what my options are for where I can run the alternator.
I don't have holes in my heads for brackets and the power steering pump is on the diver side. Will the Dorman 674-504 or 503 work? ![]() Picture of the rat motor. ![]() |
![]() Join Date: Nov 2001
Re: Ram Horn Manifolds
Why don't you use the truck ram horn manifolds?
Dorman 674-199 and 674-201 http://www.autopartsandstuff.com/sea...x?find=674-199 http://www.autopartsandstuff.com/sea...x?find=674-201 Or the 62-63 Corvette manifold with the bracket mount on it. Dorman 674-504 http://www.autopartsandstuff.com/sea...x?find=674-504 Or the 63-67 & 70-71 Corvette with bracket on it. Dorman 674-500 http://www.autopartsandstuff.com/sea...x?find=674-500
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 12-23-2014 at 11:59 AM. |
I'm that crazy guy that comes along every time I see this, because I am compelled to say:
- Pretty engine! - Get rid of that inline filter before is breaks and burns you to death - Get rid of that rubber fuel line before it ruptures and burns you to death My mother was a burn ward nurse, and I'm going off what she learned in inquests. Also do not jump and grab the power line when on a metal balcony. But that's for a different forum...
#4 | ||
lol...I have removed them already and started bending a new steel fuel line to the carb. |
I am not 100% sure but I think the straight dump manifolds work on our old trucks if the motor is in the rear position aka the 4x4 position. 2wd trucks use the angle dump manifolds.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
The straight dump exhaust are a really tight fit, and need a very competent exhaust guy to get them to work. Any other aftermarket items you have will be a crap shoot as to if they will work together with those manifolds. However, once installed, they are sweet!
#7 | |
#8 | |
![]() Join Date: May 2014
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
For my '67 I have a '68 truck 327 that had the bosses. When I built it I used old-style 64cc heads to be...old style. So, I'm in the same boat more or less. I have a set of Sanderson shorties I may use and I know brackets are made to mount the alternator w/headers. For rams horns, does anyone make such a set-up? Or, reproduce early Vette manifolds? Or, maybe the header bracket set-up could be made to work?
Can't you use the header style bracket and just get a longer belt? I did something similar in a '64 Impala years ago.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
Sorry, I edited my post.
My lanuaging was un-fixed I think that Corvette manifold Dorman # 674-504 uses the same bracket you are currently using, but I am not sure on that. http://www.autopartsandstuff.com/sea...x?find=674-504 And... I think Slow-1 is right on that the motor mount tower locations do make a difference.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 12-23-2014 at 01:40 PM. |
Here is the driver's side manifold with the built in alternator mount. Then just buy the appropriate Corvette pieces to bolt to it. They show this manifold to be for 62-63 'vette and it looks like the alternator could have been on either side in '63? So make sure you get the right pieces for driver's side install. The belt is longer on the 'vette setup if memory serves, so you may want to get the High Perf adjusting brace which I think is the brace just doubled up.
It also might be possible to use the 67-68 truck stuff. Maybe. http://www.summitracing.com/parts/rnb-674-504
#13 |
Anyone have any pictures of the center dump manifolds on there truck?
I just pulled off the driver side header and man what a pain in the butt. I had to pull most of the clutch linkage off to get it out. |
#14 |
Just installed center dump Rams Horn exhaust manifolds this month on my truck. It is a tight fit, but they work great. Picked them up through Classic Industries for $209.99 for the pair. Attached some photos below.
1967 Chevy C10 Stepside SWB - 350/700r4 |
