Old 12-22-2014, 09:33 PM   #1
dmartin1
dmartin1's Avatar
'67 327 pully questions. adding PS
1967 327 chevy.
may seem like a dumb question, but are the crank pullys the same as 350?
my engine has the 1 belt single groove pully on the crank and water pump(factory no power steering or ac)
what od i need to do to add spaces to the pullys?
i am adding power steering and eventually an ac compressor(maybe). thanks.
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 12-23-2014, 12:37 AM   #2
67CC
Re: '67 327 pully questions. adding PS
Replaced a crank pulley on my '67 327 as it was dinged. Got a chrome replacement from Summit. You can order 1 or 2 groove.
I believe it's more of the question of the year than the displacement. Earlier ones had a deeper groove and the diameters may be different. May have been a different bolt pattern later, not sure. Check pattern on whatever damper you are using
You can also do a custom set-up. Lots of pulleys are available. You just need to work out what belt length you need and get lots of pulley spacers as you will need them to align the pulleys.
If you buy an AC kit, they usually come with necessary pulleys.
'67 C20 Custom Camper. 327, three-on-the-tree. No power anything!
67CC is offline   Reply With Quote
