Old 12-23-2014, 12:50 AM   #1
thump426er
How Much Drop - Help
Hi there.
I don't know how much drop my truck has and I have a couple things planned ahead where I'm going to need to know.
I like the amount of the front, I'm planning to throw some disc brakes on all 4 corners so will need to know what spindle to keep the same height up front. May be a bit ignorant at the moment to this also, maybe all the drop is just in the coils??? Switching to 5 lug so I can throw some different rims on as well.
Out back I'd like to C-notch and drop another couple inches to get it a bit more level. I like some rake but not as much as it has.
From the pics here is there any way to get a good line of what drop has been done front and rear. Additional pics below.
Maybe someone has some stock measurements which I could figure out the drop from??
Appreciate any help.
thump426er is offline   Reply With Quote
Old 12-23-2014, 12:53 AM   #2
thump426er
Re: How Much Drop - Help
A few more
Old 12-23-2014, 07:48 AM   #3
Mr Handy
Mr Handy's Avatar
If I were to guess you have a 3"-5" drop.
My truck has a very similar stance with a couple of differences.
my truck is a longbed and I have 4"drop springs in the back (in theory equal to 5" springs on a short bed) I have 2.5" drop Spindles and stock height springs up front.
A couple of things to keep in mind. There are more than one kind of drop spindle. Most will widen your front track which is already wider than the rear. This is not an issue if you plan to run staggered rims such as 6" up front and 8" rear. If you can spec you backspacing all the better.
if you are planning to swap axle shafts make sure to get the correct length. 71/72 axle shafts will not swap in to a 68 axle. They are to long.
Do a ton of research and I suggest ECE as a Company... absolutely wonderful customer service and very knowledgeable as well... if you email them with your questions and measurements of the truck they will know what springs are in it, and they can help you get the parts you need to do the disk swap and get it riding where you want it.
Mr Handy is offline   Reply With Quote
Old 12-23-2014, 12:02 PM   #4
CST10
CST10's Avatar
Looks like a 3/5 drop to me. I have the same stance on my SWB stepside. My LWB fleetside has a 2/4 drop on it. Actually the LWB looks lower.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 12-23-2014, 12:21 PM   #5
67 cst swb
67 cst swb's Avatar
I would say it's a 3" Front and 4" rear.
My memory is that with a 5" rear spring, you are sitting ON the rubber snubber. This is still over an inch away from the snubber still.
But that's just my .02 cents
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 12-23-2014, 12:28 PM   #6
Mike C
Mike C's Avatar
The front looks like 2 1/2" spindles and 2" springs to me, and I'd guess 5" spring in the rear. Maybe a block as well? 4 1/2"/6" drop as long as we're guessing!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-23-2014, 01:47 PM   #7
67 cst swb
67 cst swb's Avatar
Can't be a 2-1/2" spindle as it's still drum brakes.
There is no block in the rear as seen it the picture above and there is
no way he could have a 6" rear spring with the bump stop still in there.
My guess is that the guy was on a budget and wanted a low truck with an old school rake to it.
So, he bought 3" front coils (or possibly cut the coil), then bought 4" rear springs for the 1" rake look.
My Trucks:
Old 12-23-2014, 01:54 PM   #8
67 cst swb
67 cst swb's Avatar
My guess is the reason your LWB looks lower is that a LWB fleetside is much heavier than a SWB stepside and a 462cid is much heavier than a 250cid 6 cyl.
My Trucks:
Old 12-23-2014, 01:59 PM   #9
Mike C
Mike C's Avatar
Check this again. Spindle has been cut and welded for drop, maybe as much as 4" just on the spindle. Definitely no block in the back though. I missed that. That's my truck and I'm getting rid of that ASAP and putting discs on it and a forged spindle.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-23-2014, 02:06 PM   #10
67 cst swb
67 cst swb's Avatar
Wow!!! missed that one... I wondered why the spring looked so.... normal.
My Trucks:
Old 12-23-2014, 03:23 PM   #11
CST10
CST10's Avatar
That might be the reason. I never thought of that being the possible cause. Thanks for that insite.
MyToys:
Old 12-24-2014, 07:13 PM   #12
thump426er
Too funny. I looked at that and only thought to myself "that looks odd for the factory to do"
So looks like if I get drop spindles say 3", I can then play with coils if I want more up front since it appears to be spindle drop now. In back I can get shorter coils say in the 6" range if you guys are thinking they currently are in the 5" range.
Currently the back tires are about 1.5" taller than fronts which is adding to rake obviously. When I figure out rims/tires and all that I can get the diameters a bit closer to level it out too I guess.
Will have to do some searching for rim backspacing guys are running for the look I'd like to get..... and brake setup.
Would like to run some bigger 13/14" disc's up front with 6 piston Wilwoods and a 4 piston in back. Any suggestion where I'd find a good price and support? Still ECE?
Thanks a ton for the info and thoughts. Very appreciated.
Old 12-24-2014, 09:50 PM   #13
Mike C
Mike C's Avatar
To each his own, but the factory brakes are pretty good with the 12" discs and 11" vented drums. Add a power booster and adjustable rear proportioning valve to get as much out of it as you can. Spend money where and when you have to. That $1000+ extra for those Wilwoods goes towards more motor or a build TH200 4R in my truck. A faster, variable ratio steering box would make the drive better than those brakes.
For a truck I'm going to drive, that's what I would do. (And am planning this exact swap next week on my '69 short step.) I'm going with ECE 2 1/2" drop spindles and 5 lug disc conversion along with 2" springs. I've got a '72 leaf rear that I'll set my 3.73 posi up in and install with a DJM flip (give or take 6" drop in the rear.) I'm going with 235 55 17 fronts and 275 55 17 rears which are 27 and 29 inches tall respectively. I'm hoping for a near level to slight rake stance. I'm adding a factory sway bar in 1 1/16" variety (because I have it) and KYB front shocks all the way around.
44 Willys MB
52 M38A1
64 Corvette Coupe
