Questions on swapping standard to Automatic
I have got a very nice 67 step side that's been previously restored.
It has a rebuilt inline 6, with a 3 speed on column and a aftermarket A/C on it not sure of the brand that the A/C is. I am wanting to put in a V-8 and a 700r4 transmission and keep the A/C unit. To make this go as simple and as quick as possible I would like to get all parts and stuff ahead of time. Anyone that has done this or has the knowledge to steer me in the right direction I would appreciate it. Starting with the steering column what years will fit and any alternative to not switching it out, and linkage to go with it, then the driveshaft since the yoke would be different what would be a good year to pick a drive shaft from, I no I would have to cut to length, and then for the aftermarket A/C the bracket is up top and high on the passengers side of engine, what would be the best way to get it hooked up to a v-8. Thanks for any advice, I have dealt with engines a good bit way back but have not done any restoring or changing around, Only time I ever did tranny swaps was in the 80's and just installed floor shifters not what I want in this case, as I want it to be as close to stock as possible. |
Re: Questions on swapping standard to Automatic
No one's ever swapped a 6, standard for a v-8, auto 700r4, with info detailing the swap.
I can't answer your question but I have found tons of info on stuff I was wondering about in the builds thread:
http://67-72chevytrucks.com/vboard/f...play.php?f=115
1967 GMC SWB 383 Stroker w/Saginaw 4sp 1979 Chev C30 Scottsdale Flatbed 350 4sp 2000 Chev 3500 Flatbed 454 Automatic 1978 GMC 6500 Flatbed Dump 366 5sp + 2sp 1965 Chev K10 LWB 230 4sp 1985 Chev K30 Flatbed 350 4sp |
Watch out for your cornhole !
![]() Join Date: Jun 2003
That's an easy swap. No driveshaft mods needed. The 3 speed yoke is the same as the 700R4 yoke. And when you swap the V8 engine mounts in place of your six mounts, the drivetrain will move forward which makes the length of the driveshaft right again. The only situations where this is true with small blocks and either 700r4 or nine inch TH350 trans applications. It's just a lucky deal.
And I'm not just talking about some internet folklore I've read somewhere. I've done it on several of my own trucks personally.
#5 | |
#6 | |
![]() Join Date: Nov 2004
Then you just need an auto cross member off any 67-72 truck. You'll also want the 700R to work right. I HIGHLY recommend bowtie overdrives. I bought their TVmadeEZ kit which they make brackets for different brands of carbs to work correctly with the trans, and their lock up kit which also uses a brake cut off switch for safety. I swapped my truck from an I6-3spd to 350/700R about 12 years ago. I burned up my first trans because I didn't have it set up right. With the BTO stuff the new trans was installed in 2006 and has about 30K miles on it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
and for the column anything from a 67-72 and all the linkage should bolt in your truck.
may have to do some minor fab work on the lower brackets and as redneck said the 3 speed x member is no fun removing
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
