Old 12-23-2014, 06:10 PM   #1
MaNdEr
Windshield Removal to get Dash out HELP ME ive never removed a windshield
so i recently bout a 67 chevy pickup and i am trying to remove the dash to sand and paint it and redo the interior altogether my trouble when i tried to remove the dash was i ran into those pesky spot welds and realized the front windshield has to come out which is fine except ive never done that on a vehicle of any kind.. im confident in my mechanical capabilities to do it myself however im not above recommendations.. do i just remove the seal on the outside and inside and pull the windshield out or??
Please anything will help... before i get brave and grab some screwdrivers and go at hahha
MaNdEr is offline   Reply With Quote
Old 12-23-2014, 06:24 PM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Windshield Removal to get Dash out HELP ME ive never removed a windshield
The easiest thing to do is to take a long sharp razorblade and insert between the outside of the windshield and the seal. Cut the seal all the way around and then the windshield will pop right out. I say this because it's easier and cheaper to replace the seal than it is to get a new windshield from using screwdrivers to try and pry it out. You could also try the rope trick but that takes a lot of patience and a few cuss words. Take a piece of 3/8" rope long enough to go all the way around the windshield, work it in between the seal and the windshield on the outside, you will need someone on the inside to push on the windshield as you slowly pull on the end of the rope as you work your way around the glass. Good luck. I'm sure you'll get a few more ideas.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 12-23-2014, 06:29 PM   #3
MaNdEr
Awesome, thank you so much.. i am going to try the razorblade trick it sounds like the easiest way to do it without breaking the windshield..
Old 12-23-2014, 06:30 PM   #4
Bishops Trucks
KEEP ON TRUCKIN'
Glad I could help. Your welcome. Also, Welcome to the board. You can find any info you need here.
JIM
Old 12-23-2014, 06:41 PM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
If all you are doing is painting the dash, i would leave the dash in.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 12-23-2014, 06:44 PM   #6
70LonghornCST
Moderator
70LonghornCST's Avatar
If you are dead set on removing the windshield to paint it, cut it out. Trust me. Ask me how I know
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 12-23-2014, 08:57 PM   #7
88Ironduke
I removed my windshield first time with no problems. Pair of good sturdy work boots and out she went. lol Did reveal the cancer hiding beneath... Always a price to be paid somewhere.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!!
My Build Thread: Project 72' Green
http://67-72chevytrucks.com/vboard/s...d.php?t=587932
88Ironduke is offline   Reply With Quote
Old 12-23-2014, 10:06 PM   #8
MaNdEr
i used two screwdrivers and a razor blade and the windshield popped right out.. very easy i will need a new seal but thats not a big deal. i used a saw and cut the spot welds out.. now i can sand and paint the dash the proper way.. i can also make sense of the wiring haha always fun
Old 12-23-2014, 10:12 PM   #9
Possmguts
Possmguts's Avatar
Yeah dont pry on it with ANYTHING... cut the seal and it will come right out... I cracked mine trying to pry it out, but Im replacing it anyway so no big deal.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 12-23-2014, 10:28 PM   #10
hotrodder
So when you re=install the dash, will the paint not burn when it is welded where needed?
hotrodder is offline   Reply With Quote
Old 12-23-2014, 10:39 PM   #11
SCHRUMGMC
SCHRUMGMC's Avatar
I'd leave the dash in personally
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 12-23-2014, 10:42 PM   #12
JointTech
JointTech's Avatar
dont cut the seal
just take a stick and a long rope. Jam the stick behind the seal from inside the cab. Shove the rope in behind the seal. Do this along the sides and top.
Have somebody stand outside and press against the windsheild to keep it from flying out.
From inside push with your feet on both sides of the windsheild so it pops out evenly.
Takes about 10 minutes and no pressure at all.
Search for Lockdoc. he has a better explanation.
Only thing I would caution is to be sure you get your rope all the way behind the seal or you arent doing anything... ask my how i know.
then you get this: windsheild trim and gasket all ready to put back in or sold.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 12-23-2014, 10:44 PM   #13
JointTech
JointTech's Avatar
here it is...
http://67-72chevytrucks.com/vboard/s...d.php?t=210843
I used an extension cord instead of a rope.
72 C20 Long Bed
Old 12-23-2014, 11:18 PM   #14
kxmotox247
kxmotox247's Avatar
I used a utility knife and just cut thru the seal from the backside. Seriously... 5 minutes and it was out.
kxmotox247 is offline   Reply With Quote
Old 12-23-2014, 11:22 PM   #15
SCHRUMGMC
SCHRUMGMC's Avatar
Exactly what I wanted to say JointTech
1971 GMC Sierra
1959 GMC 100
Old 12-24-2014, 05:59 PM   #16
Hubscrub
Cruzin
Hubscrub's Avatar
wow glad i seen the lockdoc method that's nice when you want to save the gasket.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
