Old 12-23-2014, 09:09 PM   #1
HemiChallenger71
HemiChallenger71's Avatar
Clutch
Been driving my '00 4.8 5spd. engine donor vehicle for the winter. This will find its way into my '59 chevy come spring.
I was wondering what clutch you 5spd. guys run to hold some power? Stock? aftermarket? I plan on a camshaft for mods and possibly* some spray in the very distant future. Car should be around 3700-4000lbs. with me in it, comparable in weight to the truck.
Thanks for any input.
HemiChallenger71 is offline   Reply With Quote
Old 12-26-2014, 06:47 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Clutch
A Center force DF should hold it....decent on the peddle pressure also. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
