![]() Join Date: Mar 2012
need help speedometer drive gear setup
what i have is a '69 gmc p/u 3/4ton 4x4 w/sm465/221 t/c. i need to swap out the 4:56 gears and want to go with 3:54 gears. i went and bought what i thought were correct parts and they are not. #3866919, 3866742 plus a reducer marked 1.3000 j (stewart-warner) round gear has 7 teeth, and longer gear has 22 teeth. what i pulled out (longer gear) has 12 teeth. 3866919 is much larger than what i have on top pic.
#2 | |
The Older Generation
Re: need help speedometer drive gear setup
I can't tell you off the top of my head but you might find the answer here. Or give them a call next week.... http://www.transmissioncenter.net/sp...n_______va.htm LockDoc
thanx LockDoc, i seen this link. nice site. calling is a good idea. plus im not sure what tires im going with. i have a master parts book with all part numbers which helps and what i did was purchase the parts for the 3:54 ratio and they are wrong
