Old 12-24-2014, 03:13 PM   #1
bean
best cfm for a stock 305?
Is a 600 cfm best recommendation for a stock 305? Thinking about going from stock q jet to an edelbrock. .. any feedback is appreciated
bean is offline   Reply With Quote
Old 12-24-2014, 03:23 PM   #2
stomper
Junior Member
stomper's Avatar
Re: best cfm for a stock 305?
I had a 500 cfm edelbrock on a hot 283 once. It was snappy. The advantage of that small carb was increased intake velocity. A common mistake is to go too big and it's sluggish on throttle response. I'm sure there are formulas out there for you.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 12-24-2014, 03:31 PM   #3
bean
That's my concern is going too big
Old 12-24-2014, 03:49 PM   #4
wreckedchevy
wreckedchevy's Avatar
I'm running a edelbrock 600 on my 305 the motor does have bigger cam and 202 heads on it ran ok with stock jetting but just got it jetted properly this summer and it runs outstanding now.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 12-24-2014, 03:49 PM   #5
mechanicalman
First of all, what kind of problems are you having, if any? I can expand on my comments if you tell me what is going on. Plus, I need to know if you have the original style quadrajet (divorced choke) or the later model style with round choke housing, again, to expand my comments.
Stomper is right, larger than necessary carburetors exhibit lower velocity than properly sized carbs.
Therefore, you should either keep your quadrajet or fix it. Quadrajet's have the smallest primary butterflies of any 4 barrel V-8 carb I've ever seen and appropriate venturis.
Quadrajet's were used from the factory on many engines including V-6's. They have an adjustable secondary air valve that allows the use of any engine that the primaries are not too big for, only allowing the secondaries to open as far as the engine demands them to.
For instance, Quadrajet # 1904 is designed for 305-350 engines.
http://www.summitracing.com/parts/edl-1904
To answer your question, as a general rule, 600 CFM a little big for a stock 305, I'd go with a 500 CFM Edelbrock.
mechanicalman is offline   Reply With Quote
Old 12-24-2014, 04:02 PM   #6
ssxty8
A nice 305 can't consume all the performance a 600 vacuum secondaries can offer. I tell you cause that's all I have on my mildly modified 350, and it runs flawlessly. A 600 or 650 can supply enough gas/power up to around 400 HP; some people just want the bragging rights of 750+ CFM carburetors.
Oh, this is JMHO
Merry Christmass to ALL.
ssxty8 is offline   Reply With Quote
Old 12-24-2014, 04:05 PM   #7
bean
Right now using the q jet off my original 359. It has the choke still on the side but no place in the manifold for it. Using that for the meantime
Old 12-24-2014, 04:07 PM   #8
bean
It's completely stock just wanting a good running truck for back and forth to work
Old 12-24-2014, 04:17 PM   #9
71K20chevy
71K20chevy's Avatar
The formula for finding CFM is CIDxMAX RPM/3456
305 x 4000(how often will the engine ever go past 4k RPM?)/3456=353
Obviously carbs that small aren't very plentiful, so something pretty small (500 cfm or under) would work fine.
That said, I'd keep the QJet, they really are great because the small primaries allow for great throttle response but the larger secondaries open up only when you need them, so you can have great drivability and gas mileage while still being reliable...that is if it's tuned right. Can't stress enough how important that is, I'm a firm believer in the Qjet myself, because they really are great when everything is set up correctly.
Just my 2c.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
