Old 12-25-2014, 02:15 AM   #1
72supermike
Chelsea PTO, for SM465
I took this off of a truck I once had. It was mounted to the left side of the sm465 on a 3/4T 4wd truck. It seemed to work fine but it wasn't driving anything. So I removed it thinking that someday I might have a use for it. That day isn't going to come. It could use some cleaning. $175 shipped lower 48
72supermike is offline   Reply With Quote
Old 12-25-2014, 12:46 PM   #2
mx289
mx289's Avatar
Re: Chelsea PTO, for SM465
Hi Mike.
What kind of shape is the shaft in ? Any excessive wear ?
How are the gears ?
Do you have the cable and floor mount ?
Thank you much
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 12-25-2014, 02:36 PM   #3
72supermike
Originally Posted by mx289 View Post
Hi Mike.
How are the gears ?
Thank you much
The shaft is in good condition without any excessive wear that I noticed. The gears looked good as well. And, no, I don't have the cable and floor mount. It does engage and disengage easily.
Old 12-26-2014, 10:59 AM   #4
mx289
mx289's Avatar
Thanks Mike.Sounds good.
So,all I need to install would be cable and floor mount ?
Do you have the mounting bolts ?
Would you consider $150 shipped ?
Thanks.
Tom
71 K2500
71 K5 Jimmy
Old 12-26-2014, 09:27 PM   #5
72supermike
I don't have the mounting bolts. They were used to install the cover plate back on the transmission. You would need a cable, like a transmission shift cable, or something similar, and a mount with a knob or something for engaging and disengaging the pto.
