Old 12-26-2014, 04:15 PM   #1
merlin3
weight of bed
does anybody have a idea what a 6ft. fleet side bed for a 72 c10 weighs? thanks
merlin3 is offline   Reply With Quote
Old 12-26-2014, 05:17 PM   #2
davepl
davepl's Avatar
Re: weight of bed
6' bed is about 320 pounds. That's from a newer truck, but should be close. Four guys.
I found mine to be a LOT heavier until I found the extra strap the original owner had added between the trailer hitch and the bed rails. Just about snapped my lift before I realized "there's no way it's that heavy...."
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-26-2014, 05:18 PM   #3
Possmguts
Possmguts's Avatar
Re: weight of bed
I dont know the actual weight but it only took me and 2 friends to lift the whole thing off without the tailgate on it if that helps
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 12-26-2014, 08:33 PM   #4
Tzclark
Tzclark's Avatar
Re: weight of bed
Me and my brother lifted mine off the stand and put on it on the truck, then I went to the doctor because I blew my intense out my a$$.
1972 Chevy shortbox, done up 396bbc
1968 Plymouth Roadrunner, 1000hp twin 72mm turbos
2017 F350 Lariat, 6.7, stock except leveling kit and larger tires
2014 nissan pathfinder sl (the kid hauler)
Tzclark is offline   Reply With Quote
Old 12-27-2014, 12:02 AM   #5
'68 Newtricks
'68 Newtricks's Avatar
Re: weight of bed
I feel like my original 8' wood floor bed was lighter or close to my Repo steel floor 6' bed. Me and one person, but I swear the 6' felt heavier.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 12-27-2014, 12:51 AM   #6
Tropical Snowstorm
Lurky lurky
Tropical Snowstorm's Avatar
Re: weight of bed
I would guess 400 lbs or so. With 1 person on each corner I've taken a few long beds off with tailgates attached and not had too much of an issue.
Tropical Snowstorm is offline   Reply With Quote
Old 12-27-2014, 01:20 AM   #7
SS Tim
SS Tim's Avatar
Re: weight of bed
415lb is the difference between a chassis-cab and a fleetside on a 107" wb.
GM lists the E81 floorboard (wood bed) to be 15lb heavier without distinction as to length.
SS Tim is offline   Reply With Quote
Old 12-27-2014, 01:13 PM   #8
Rocket3
Rocket3's Avatar
Re: weight of bed
I weighed a long bed with steel floor and tailgate at local CO-OP scales on my trailer. The amount of gas I had between full/empty trailer was different,so I had to give it a range of 460-500 lbs.
Rocket3 is offline   Reply With Quote
Old 12-27-2014, 03:04 PM   #9
kcsa75
kcsa75's Avatar
Re: weight of bed
Like some of the others, I've moved several longbeds with two of my sons/sons-in-law and me. Not really a problem at all.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 12-27-2014, 04:53 PM   #10
merlin3
Re: weight of bed
thanks for the replies
