12-26-2014, 07:27 PM | #1 |
Best shaved firewall kit?
Who offers the best looking/fitting shaved firewall kit for an AC cab? Also, what gauge of sheet metal do you recommend to fill in random holes?
12-26-2014, 07:58 PM | #2 |
Re: Best shaved firewall kit?
What are you referring to when you say "AC"
I.E. what the cab came with from factory? Mark..
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
12-26-2014, 08:01 PM | #3 |
Yes. I have a factory air conditioned 69 cab. I want to smooth the firewall as much as possible. I will be using a vintage air kit in the future, however I am planning on running a bulk head and hiding the lines under the passenger fender.
12-26-2014, 08:07 PM | #4 |
Here is what I did on a 67 for a customer...
I started with a stock firewall and made my own filler panels as needed. some of it was 18gauge some was 16g
12-26-2014, 08:10 PM | #5 |
Here is a few more...I am a fabricator by trait and this is easy stuff for me to do. a shaved firewall kit you will have to remove most of stock unit...
I opted for making panels..
12-26-2014, 08:14 PM | #6 |
Here are 2 more shots as it was being done.
The last one was the final look..
12-26-2014, 08:25 PM | #7 |
Thank you for the pictures! That's exactly what I had in mind. I'd also like to smooth out the wiring gutter. I've seen a few pictures of this done, but I can't find them now. What are your thoughts on that? Any downsides?
12-26-2014, 08:34 PM | #8 |
I have done that on 2 of these now
Will look for.pics on that part No down sides!!!!
12-26-2014, 08:46 PM | #9 |
Here are 2 more of the firewall and the gutter...
Sorry I couldn't find "in progress" pics of this! just as it is in primer... 2nd with bulkhead.. If you need anymore let me know or even PM me Mark..
12-26-2014, 11:36 PM | #10 |
Used porterbuilt's panel for ac side...1 1/4" flat bar for wire gutter....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
12-27-2014, 09:57 AM | #11 |
Thank you for the pictures guys. What gauge was the 1 1/4" flat bar that you used or recomend? These pictures are great by the way. Seems as though this topic comes up alot. It would be nice to have a thread just for shaved fire wall pictures. If there is one, it would be nice to be able to find it easier! You guys did a fantastic job on those trucks! Keep the pictures coming if it's not too much of a hassle!
12-27-2014, 03:06 PM | #12 | |
12-27-2014, 03:09 PM | #13 |
Here's link to p.b.'s kit.....this is Travis at properformance ad....he's a vendor on here.....jim
http://www.azproperformance.com/Port...er-Panels.html
12-28-2014, 11:38 AM | #14 |
Thank you the pictures as well as the link! I didn't notice you smoothed out the hump above the trans tunnel until you mentioned it. I really like subtle changes like that! Also, is that kit you guys linked to az performance for an original ac truck cab? Thanks again!
