64 c10 need to pass emission
I have 64 c10 with four barrel carb on a 350. My truck is overseas and even our classics have to pass emissions. The problem HC limit is 1200 ppm but mines read 5700ppm. Now there are no obvious problems, engine runs good. When I bought the truck I always noticed strong fumes coming from exhaust but you know older babies do that sometimes. The carb, intake manifold, and related gaskets are new. Any ideas where I can start to check?
Also another issue the truck has the halogen light for the headlight and no high beams. The blinkers work fine but the left blinker it is much dimmer than the right blinker and when I turn on parking lights they do not come on, any ideas how to get brighter blinker( I changed the bulb already) and get the parking lights to come on? |
Re: 64 c10 need to pass emission
light problem is lack of GROUND
![]() Join Date: Sep 2006
Parking lights are not designed to come on with the headlights. To do so you have to connect the purple wire and I can't remember the other color at the switch. Check a wiring diagram, or someone here can remember which one.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
![]() Join Date: May 2007
edit: I see Chevy Fleetside has given this idea first.
obtain and install a "smog pump", they are common on 70's and early 80's vehicles. They pump air into the exhaust manifold and, while there is a tiny little extra burning of hydrocarbons with the extra air, the main benefit is that it changes the ratio of HC to O2 by increasing the O2, usually to an allowable limit. alternatively, you could install a catalytic converter in the exhaust and actually burn up the hydrocarbons.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
There is a bit of important information missing to give more than just general ideas. What carb is on your engine? What ignition? Where is the timing set at? When was a tune up last done? Is the engine stock? Are you certain it is a 350?
See how they chime in... You could probably write a 2 page post on this stuff.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
You said you smell fumes , what carb do you have ? have you adjusted the idle mixture screws?? have you checked the timing ??
I have a demon carb, timing is good but I have not adjusted the idle mixture screws, I was thinking to do that to see if it will reduce the fumes and then go take it back for another test. Also it takes a good wild to warm up don't know if thats related or not.
I believe a Demon Carb is a performance carb. Not really an emission carb.
#13 |
It probably has a performance cam shaft in it also. But I wouldn't know since I didn't build it.
#14 |
Install a smaller carb designed for better economy. Cut the last 3 feet of exhaust off and weld up a cat converter and a cherry bomb with a bolt on turn down. Drill a hole vertically through the pipe just behind the glass pack. Test fit a body washer and drop a nail through the hole to hold the washer. Stuff the glass pack with 2 bags of steel wool and install the washer, nail and the turn down a block away from the inspection station. Idle in and pass inspection. Remove the temporary exhaust and bolt the demon back on.
Dont ask how I know this works.
GOD BLESS AMERICA! |
#15 |
Who Me?
I would think some cats would help burn off the bad stuff.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#16 |
Thanks for all the advice, got the lights working, found wiring schematics , purple wire was cut, wires criss crossed and ground problem. that socket holder didn't want to ground when popped in. Now I'm about to play with the carb.
#17 | |
#18 |
There is always the rubbing alcohol in the gas tank trick. A buddy used to get a mid 80s firebird to pass with no cats in CA...
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE |
#19 |
jolobo, google Georgia's Clean Air Force for all the info on what needs and what doesn't need emissions. I think your in the clear unless you just want a cleaner running truck.
#20 |
Sorry jolobo, I read your post wrong thinking your truck was going to be shipped here from overseas.
#21 |
#22 |
Re: 64 c10 need to pass emission (pics + oil leak)
I have an oil leak from the front, see pics. I notice there is a hole (q-tip) opposite the water hose. The oil seems to be coming out of that threaded hole and hitting the water hose and running down. What is that hole for and should there be a screw with some type of o ring or washer to close it up?
#23 |
![]() Join Date: Jan 2011
A short bolt is all you need with a washer on it. The hole is to put a longer bolt in to hold the fuel pump shaft when changing the pump. Don't use a bolt longer than about 1/2" long. It's 3/8 16.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#24 | |
